Rfoley22
- December 31, 2008
- Littleton CO
- 92 XLT
I recently re-built my '92 explorer's A4ld Transmission, all went well, replaced all soft parts, and some hard ones. endplay is in specs. replaced the torque converter as well.
Post re-build it shifts perfectly. strong shifts that are firm but not harsh. no jolts and whatnot. Also no slipping!
Problem is that it now shifts at the wrong speeds. 1-2 is over 35mph and only then with foot off gas. (this was a problem before but not as much)
very difficult to go over 55 in overdrive. (lack of overdrive?)3000-4000rpm
very difficult to go over 45 in drive. (lack of 3?)3000-4000rpm
2-3 shift is on time, usually.
problems found during overhaul were stuck valves, broken valve spring, and lots of sludge. friction material was also very worn.
I did not replace the servos, Solenoids, or the modulator.
could this be the modulator, servos, or solenoids? if not then what are other ideas?
could it be a bad torque converter?
gears inside are good, friction material is good, fluid is less than 2 days old 100% replaced. what are likely problems?
