- September 6, 2006
- South Central PA
- 1994 Explorer
- Callsign
- yosty
This How To Thread was originally written and illustrated by @94fourdoor
This is for informational purposes only and any and all problems/accidents/injuries/divorces/pimp-slaps/etc. that may occur are the sole responsibility of the person that refuses to man-up. That being said, here we go.
Unfortunately, my computer crashed during the process of the swap and taking pictures and A LOT of my pics were lost, for this I am truly sorry as I tried hard to take as many photo opportunities as possible. Between the few that I was able to recover and the ones I had already saved to the internet, I have the bare bones basics. If anyone has any pics that might help/benefit someone attempting this swap, please send them to me and I will be sure and credit you in my thanks.
***It should also be noted that, besides the transmission itself, I used all new parts for this swap. I can tell you right now that it makes the swap itself A LOT easier and peace of mind after it is finished. If you do not use ALL NEW parts during this swap, AT LEAST USE A NEW SLAVE CYLINDER AND THROW OUT BEARING!!!! It is one of the harder parts to change out when it fails and for the price, cheap insurance!***
Additional important info added here as received:
Courtesy of @snoranger: If you have a 93-94 Limited, The dash harness is not the same as any other model. You do not have the jumper plug for the clutch switch. They came as auto ONLY, you will have to do your own wiring.
A how-to on auto to manual swap -1st gen.
I am going to skip all the crap about jack stands, disconnecting the battery and all that jargon to save space, so do the basics and you should be ready to go! It should also be noted that you should remove your mud guard/wheel well cover on the drivers side, prior to starting this swap, for better visibility and ease of parts removal/installation.
Here we go!
I started with disconnecting the driveshafts, transfer case skid plate, and starter, setting them aside.
Take the time to drain the fluid out of the trans now, before you get too involved in the swap. After it's drained, remove the cooler lines on the side of the trans and also remove the cooler itself (it can be a little tricky getting the lines out from around the engine, but you aren't going to need them later, so I just bent mine up pretty good getting them out.)
Next, disconnect the plug and the speedo cable on your transfer case and move them out of the way.
Once that is done, place a floor jack under the transfer case for support and remove the bolts holding your support brace to the auto trans. SAVE THEESE BOLTS as you will need them for installation later!
Gradually lower the jack down until you can reach the two bolts on the bell housing holding the trans to the motor. NOTE: it may help to place a jack in a secure location under the front of the engine for support later in the removal process. There is a vent tube on the top of the auto trans, just pull it straight up and it should pop out... toss it as it will not be re-used. There is also a vacuum line that runs down to the pass. side of the trans, disconnect and remove. MAKE SURE YOU PLUG THE VACUUM LINE AT THE JUNCTION UNDER THE HOOD!!! Your local parts store should have little vacuum caps on the cheap. Make sure you get one that fits, otherwise you will end up with a poorly running swap!
Unplug the oxygen sensors and remove them from the exhaust.
Here we go!
