have2goski
- May 25, 2003
- Columbus
- '91 Eddie
I am looking to do a little work on my tranny.
First, I would like to address the reverse hesitation. I have searched and found that their is a O-ring change to do that may help the problem.
Second, I will be changing my current filter to the Microfelt filter available for the 4R55E. My understanding is that this filter is considered an 'upgrade' to the old ones used in the 4x4 A4ld.
I found some part numbers for ordering from bulkpart.com that Opera House had posted before.
Could sombody that has ordered this stuff help clarify what is included in the kits.
I am looking at the 23031 overhaul kit.
What exactly is included in it?
Other Part #'s at bulkpart.com
23921 MicroFelt Filter 4WD long pickup tube
23270 O-ring Large
23271 O-ring small
23141D Pan Gasket
I need to figure out what i need to order to try and fix the reverse hesitation as well as to change/upgrade the filter.
once that gets cleared up, I have also thought about installing a shift kit while i am at it. I haven't found as much information on these through searching.
I was thinking about the TransGo kit from what I found through searching. anybody have any info on one of these? or know if bulkpart carries it? I found a transgo kit in their index but don't know if it is what I am looking for or not.
Thanks for the help.
23270 O-ring Large
23271 O-ring small
23141D Pan Gasket
