Elias lopez
- December 8, 2016
- Beaverton
- 93 Ford Explorer
My 93 Explorer has always leaked transmission fluid. Not sure what gasket or seal it is but it’s between the engine and transmission. This week I took it to the dunes, it was really fun the explorers drove great! And one part in the sand it was a bit deeper and I tried to get out. My brother told me he saw flames so I shut it off. And all of the transmission fluid dumped where it normally leaks and it was smoking and blistering hot. So we added only a quart of transmission fluid to try because that’s all we had and we let it cool off. We drove it about 100 feet and all of the fluid dumped again and it smoked. so we parked it and repeated until we got it back. The truck never went into a higher gear, it maxed out at 6 rpm in the first gear. I’m assuming because it was so low on transmission fluid but I’m assuming it’s possible I damaged other things with no fluid. If anybody could let me know if I should just get a new transmission at the pick n pull or try and replace the gasket and sensors and fluid. And if so what’s the gasket called. Right now Iran parked at the camping grounds overnight, and we’re picking it up with my dads 92 f-150
