wileys_farm
- December 28, 2006
Ok new guy here, I got a 93 ford ranger with a4ld 2.3. fresh rebuild on the tranny about 10,000 miles ago. It was driving great then all of a sudden got in it one day shifted from P to OD and it wont pull out, I moved down to 1 and it pulled out fine. I can move the lever into OD and nothing, just a little surge like it wants to lock up but it wont. I can move the selector into 1 or 2 and it will kick in gear everytime. I can manually shift going down the road and I do have drive and OD. It does kick in and out of OD like it is going in neutral or something.
Fluid is bright red and filled, I have large external cooler installed with overhaul, I have changed modulator valve, done a band adjustment, and checked vacuum on modulator valve. All with no help to the situation.
any suggestions?
any suggestions?
