A4LD vs. M50D-R1 | Ford Explorer - Ford Ranger Forums - Serious Explorations
A4LD vs. M50D-R1
explorerman3
gurnee, illinois
1991 ford explorer eddie
Hey guys, well I was recently offroading with my 91 Explorer (5.5in suspension lift, 35in mud terrains, 4:88 gears and a detriot locker in the rear). I just had the engine replaced and the trans rebuilt about 8-10,000 miles ago. Anyway, I was hung up and was rocking her back and fourth and was about to break free, when I went to shift back into drive when all of a sudden nothing happened except a grinding noise. I already know whats wrong with it because I took it back to the shop where I had the trans rebuilt, and they said i broke the good ol' A4LD again! I am under the impression that in 91-94 the manual transmissions used in the explorers was the M50D-R1 and the automatics (mine) was the A4LD. Also I am under the impression that the M50D-R1 is stronger than the A4LD, does anyone know this to be true? I ask because there is a manual trans out of another 91 explorer thats close to where I live for sale on ebay. They still have the truck that the trans came out of, and I could pull off everything that would be necessary to do the swap from auto to manual. I was wondering if this would be at all beneficial to do in place of my automatic? Would I see any benefits or improvements from doing the manual swap instead of rebuilding the auto A4LD? Any help would be greatly appreciated.
HahnsB2
Battle Ground WA
88 Bronco II
M5OD is 100X better than an A4LD. I wouldn't even think twice about throwing that A4LD in the dumpster and doing an M5OD swap, you'll probably get better gas millage too.
