5.0L96Exp
- October 23, 2005
- Ottawa, ON
- 96 XLT
Finally got around to installing my Pro Comp AAL (they now come with the 3/8 bolts) and WAR153 shackles. I would highly recommend replacing these at the same time. IT WILL SAVE YOU from having to remove the factory trailer hitch. i.e. with the axle u bolts removed, the springs will arch enough that you can get the frame-shackle bolts out no problem. Oh and I also swapped the drivers side and passengers side leaf packs.
