mparc
- December 1, 2014
- 2004 Aviator; 1999 Expl
Hi,
Great forum and lots of help for various projects I've tackled. I have a 2004 AWD Aviator 190K miles. (posted it here since it shares components with the same year Explorer).
I have a slight bearing growl coming from the front at very low speeds. It varies with speed and become inaudible over 10 mph. If I shift into neutral while rolling, the sound goes away. The front left wheel ABS has activated 3 separate times when lightly braking on a curve on a mountain road at 45-50mpg and it shouldn't be (quite shocking actually when it happens). I replaced the wheel hubs, no change to the sound (which I suspect is from the front differential now) and the ABS still activates when it shouldn't. The CV Joints have never been changed but the boots are still good and there is no binding or popping. I ve searched this forum and others and can't find anything with these same symptoms. Any ideas?
Thanks!
Thanks!
