ABS and Traction Control Lights
bobtylerjr
2007 Explorer Eddie Bauer
2007 Explorer, V6, 4.0 Liter, 4WD
ABS and Traction Control warning lights have been illuminating beginning after startup and at low speed (Just after vehicle begins to move) and remain on until vehicle is shut down. I used an Innova 3100j+ to obtain codes on the ABS system and received the following:
B1342 ECU Internal Fault
U1900 Communication BUS Fault
B1676 Battery Voltage Out of Range
U2023 Fault Received from External Node
Any thoughts, ideas, suggestions for a solution to this problem(s)?
Thank you!
bobtylerjr
Here’s and update...
Ran code reader again and only received a B1342 ECU Internal Fault
I also cycled the 4x4 and it DID engage and disengage.
Any thoughts would be greatly appreciated.
Thank you!
vipersinu2
The Big City of Orange City, Florida
2019 Navigator 450hp
Thank you!
I think you have to get a new battery
vipersinu2
Did on my truck,
Wouldnt hurt to get battery tested
bobtylerjr
Had the battery tested. It has a bad cell. Replaced battery (under warranty). ABS and Traction Control Light still illuminating. Ran code reader again and received B1342 (with engine running because the warning lights turn off at shutdown and do not reiluminate until the vehicle begins to roll). Cleared all codes in memory via the code reader. Drove vehicle. Same result, ABS and Traction Control illuminate around 10mph
Other ideas?
Thank you
vipersinu2
How are the wheel bearings?
ohm out the wheel speed sensors make sure they are good, and check for voltage at sensors.
check to see if the exciter rings are still in place
bobtylerjr
Installed a new 40 amp fuse in slot number six for the ABS With new fuse installed ran rental code reader (Innova 3150 - couple models up from my Innova 3100j+) from Autozone, resulting in ABS light only and codes C1095 Pump Motor Circuit Failure (new code) and previous code B1342. Reinstalled old 40 amp fuse and all lights and codes went back to what I previously stated. So, slightly different codes and warning light illumination depending on the fuse. Not sure what that means other than maybe the pump has failed?
Trying to avoid having to pull wheels, etc
vipersinu2
I dont see any other option, but to pull the wheels, jack it up 1st and check for play in the wheel bearings.
MotorCityFats13
Flatrock MI
2007 Explorer XLT 4.0L
I had a single abs sensor fail and 4x4 would not engage ....trac control and abs lights were on and I didnt know what systems were turned off until i took off from a light roasting 1 rear tire so I knew all systems were disabled.... so I would guess its not a single wheel bearing or sensor
