tdapsr
- November 20, 2007
- San Diego, CA
- 00 Eddi Bauer
2000 Explorer 2WD with ABS. I just replaced the front wheeel bearings, hub rotor assembly (Napa Premium) on the front (both sides) and installed new brake pads (semi metalic). I also completely flushed the brake fluid (front and rear) starting with the right rear, left rear, right front, and left front. Now once in a while usually when my speed is very slow (around 5 miles an hour and i depress the brake petal the ABS kicks in. I re-bled the system and it still does it. Any one know what may be causing this?
