fixt
- November 15, 2010
- North Carolina
- 1996 5.0L XLT AWD
Hello to all.
I have some ABS questions, having researched for information about the system works I don't understand everything I know about it. Specific information is a little difficult to find.
Vehicle is a 1996 Explorer XLT, 5.0L AWD, 129050 miles recently purchased in great condition. ABS light was set on.
I pulled codes with Innova 3160. There were 4 and I did not write all of them down.
C1185 ABS Relay output circuit fail
C1186 ABS Relay output open circuit
C1155 Left Front wheel speed sensor input circuit fail
don't remember the other
Erased the codes, ABS light off. Drove vehicle for short trip.
Turned ignition on, ABS light clears after test completes. Start engine, ABS light clears.
All is good (maybe). I was surprised it cleared.
This morning, ABS light fails to clear.
C1155 LF wheel sensor again. Erase fails (as expected) only briefly turning off light, failure is sealed in.
30F this morning, 65F yesterday at test.
Speed sensor should check at about 1000 ohms?
What ohms range is considered good?
Am I on the right track here?
Great info here, been doing a lot of reading.
Thanks for the help.
