ABS light frustration
EdmondsXLT
Edmonds, WA
2003 Explorer XLT 4.0 AWD
My ABS light comes on intermittently when driving and stays on until I turn the car off. When I turn it back on the light is off. I can't pinpoint what causes it exactly, but it seems to happen most often when accelerating hard from a stop, usually while turning - such as turning onto a busy road and trying to get up to speed quickly. One time when the light was on I stopped at O'Reilly's to get it scanned (while idling in the parking lot) and the reader couldn't find any codes.
I've recently replaced both front hubs with units that included new sensors. The light came back the next day, so I figured the rear sensor was bad. Finally figured out where the rear differential sensor was located and replaced it. The light came back. So now I'm stumped. Any thoughts on what else to check? The rear hubs/bearings are at the top of the list to replace, but seem like a huge pain which is why I haven't gotten to them yet.
I have an '03 V6 with ~185K miles on it.
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
fordysenior
True Northern California
2002 Expl 4x4 XLT 4.6L
I recently had a problem with my vehicle and took it to the auto parts stores to get scanned -- they came up with nothing. I then took it to the dealer, they scanned it and told me what was wrong with it. You might want to open the wallet and get a diagnosis done at the dealer.
EdmondsXLT
Edmonds, WA
Boooo! (lol) How much does a dealer scan run?
imp
Location
West-Central AZ along the Colorado River
59 Ranchero F250 D'Line
@EdmondsXLT
There are various "grades" of scan tools available. The "cheapies" cannot read ABS, Air Bag, and transmission codes. It's possible the place which checked for codes for you grabbed and used a scan tool unable to read ABS. I cannot imagine your problem NOT generating a code. ABS codes are "thrown", most of them, by the ABS Module itself. It even has the capability of "killing" the engine (happened to me). imp
mountaineer2004
2004 Mountaineer (V8)
My ABS light has been on for many years. My airbag light has been on for many months.
My solution to both problems was to cover them with black tape, and forget about them.
Especially as the car ages and increases miles (mine has 221K),
I care less and less about the small problems.
As long as the car goes, stops, has no "red" warning lights, and passes inspection. I'm happy. YMMV.
  • Like
Reactions: imp
fordysenior
Depends on the dealer in your area -- from $80 to $105 in my area. Until that was done, I was chasing repairs that weren't the problem. And I find that frustrating.
Also, have you tried ForScan -- it's a downloadable free scan software. I had an ABS light go on, and it told me it was my left front. You can get a connector cable from Amazon. I really don't know how to work ForScan worth a darn as I have no training in scan tools since the old days of big machines sitting in front of the vehicle. And I have too many other things to deal with and frustrate me. :)
Gilligan
Colorado Springs
2004 Ford Explorer Sport
First Thought: I purchased a code scanner from Harbor Freight for less than the cost of your dealer scan. It reads brakes and transmission codes. Most auto parts stores will read you codes for free. You may have to look for one with a better code reader.
Second: I've fixed several ABS light issues when I found breaks in the door harness wire bundle where it bends at the hing. Check any door that has a seatbelt coming from it. The ABS light will turn on if it is unable to get indications from the seatbelts.
Third: Because the ABS system has a direct affect on the control of a vehicle, for safety, the ABS system will disable itself any time there is any other trouble code in the system. So, even an catalitic converter code can disable the ABS system. You will have to fix any other soure of codes to get the ABS LED to clear.
Forth: Dealer mechanics can be as worthless as any mechanic I've encountered and 4 times the price.
And Fifth: Harbor Freight has a 10 dollar panel removal tool kit and you can get a package of any panel mounts you might need at any auto parts store for less than that.
Hope this helps
Gill
Gilligan
Colorado Springs
About the airbag light...
All air bags are required to be inspected every ten years. Many systems will turn this on the light when this inspection is required.
imp
Location
@mountaineer2004
You have been lucky, and I was not. My ABS Module had failed, it's main "chip" was found to be dead. That fact shut down the vehicle. I replaced the module with a used one, and things are working well again. imp
mountaineer2004
@mountaineer2004
Wow, that's not good. Didn't even know ABS stuff could shut down the vehicle. Another reason not to like it.
  • Like
Reactions: imp
imp
Location
@mountaineer2004
As I see things, having also Automatic Traction Control, or whatever the hell they call it, confounds the issue even more. A far more complex ABS system capable of applying the brake at any wheel independently of the others, at any time the program demands it. When faults occur, watch out!
imp
TechGuru
Location
Texas
2003 XLS 4X4 4.0L FLEX
It would be cheaper to just use ForScan ($30 for the USB OBDII adapter) than to take it to a dealer to be read. ForScan can even force the ABS pump on for ABS bleeding.
TechGuru
Location
Texas
How would the system know the current date?!
  • Like
Reactions: imp
mountaineer2004
My airbag light only came on a couple of months ago. It's 15 years old.
  • Like
Reactions: imp
Mrobs146
Westland, Michigan
2003 xls 4x4
Did you ever figure out the problem cause everything you’ve replaced I have as well. Front hubs with sensors, rear abs/speed sensor, and light comes on when taking off too it’s annoying as hell!!
B "05" XLT 230K miles ABS light on but with a kicker!! Stock 2002 - 2005 Explorers 2
K ABS Warning Light Stock 2002 - 2005 Explorers 2
F No ABS, RSC, or A4x4 - light flashing 8 times - Help! Stock 2002 - 2005 Explorers 2
M ABS, advancetrac, and 4x4hi light Stock 2002 - 2005 Explorers 28
E Abs light on and 4x4 high light flashing Stock 2002 - 2005 Explorers 4
A HELP! 05 Explorer stuck in park, ABS light on Stock 2002 - 2005 Explorers 16
L 2002 Explorer 4.0 ABS Light Stock 2002 - 2005 Explorers 9
J 2004 ford explorer ABS light Stock 2002 - 2005 Explorers 6
ProjectAviator ABS light on 05 EX with advance trac Stock 2002 - 2005 Explorers 2
J ABS light after burnout. Stock 2002 - 2005 Explorers 1
B ABS Light On - No Code Stock 2002 - 2005 Explorers 8
J 2004 Explorer (K) flashing O/D off light ABS light. Stock 2002 - 2005 Explorers 2
T ABS Light on after wheel bearing change Stock 2002 - 2005 Explorers 15
D 2004 Ford Explorer ABS and 4wd Light questions Stock 2002 - 2005 Explorers 4
F ABS light on and Door Ajar Light on Stock 2002 - 2005 Explorers 2
M ABS light Stock 2002 - 2005 Explorers 3
B ABS light (first time) Stock 2002 - 2005 Explorers 9
R ABS light came on after Left front Hub replace Stock 2002 - 2005 Explorers 11
F ABS light comes on intermittently Stock 2002 - 2005 Explorers 15
G Test drive: ABS light came on, flashing 4x4 high Stock 2002 - 2005 Explorers 7
Exproblems Strange Occurrence: ABS Light, 4x4 High, Check Advance Trac Dash lights came on! Stock 2002 - 2005 Explorers 0
H Solved Cruise control and ABS light not related Stock 2002 - 2005 Explorers 2
G 02 explorer o/d light and abs light Stock 2002 - 2005 Explorers 0
S Abs light what it will take to turn it off Stock 2002 - 2005 Explorers 5
B ABS light and Shuttering slowing Stock 2002 - 2005 Explorers 4
W ABS light and a whistling dash when cold Stock 2002 - 2005 Explorers 3
F ABS light, flashing 4x4 HIGH light Stock 2002 - 2005 Explorers 1
S help ABS light ??? Stock 2002 - 2005 Explorers 10
C ABS light on Stock 2002 - 2005 Explorers 0
R ABS light on, 4x4 high flashing, binding when making turns. Stock 2002 - 2005 Explorers 4
S Ruh Roh.. cv bind I think. abs light on? Stock 2002 - 2005 Explorers 5
G ABS - Advance Trac - 4X4 light coming on Stock 2002 - 2005 Explorers 0
K Cruise control turns on but doesn't engage. ABS light is on Stock 2002 - 2005 Explorers 1
P ABS Light has been on for 2 months. Stock 2002 - 2005 Explorers 10
L I need help with my abs dash light Stock 2002 - 2005 Explorers 3
V abs light and advance trac off light came on when it was cold out Stock 2002 - 2005 Explorers 2
S ABS light comes while towing Stock 2002 - 2005 Explorers 2
C ABS light coming on and off Stock 2002 - 2005 Explorers 3
S ABS Light Stock 2002 - 2005 Explorers 3
P ABS light Stock 2002 - 2005 Explorers 1
F 2002 Ford Explorer ABS light on please help! Stock 2002 - 2005 Explorers 17
J ABS light, AdvanceTrac, 4x4 high lights Stock 2002 - 2005 Explorers 0
X ABS Light on, drivers side rear wheel locked, all others moving Stock 2002 - 2005 Explorers 2
T 2004 4.6 ABS light on and 4x4 flashing, Cruise still works Stock 2002 - 2005 Explorers 1
M 02 Mountaineer AWD V6 abs light under full throttle Stock 2002 - 2005 Explorers 2
J 2002 explorer abs light comes on Stock 2002 - 2005 Explorers 17
E 04 explorer abs light on. 4x4 light blinking. Stock 2002 - 2005 Explorers 1
D ABS Light on and ABS not working Stock 2002 - 2005 Explorers 2
C 05 Explorer ABS light and Advantrac Light came on Stock 2002 - 2005 Explorers 0
J abs light and 4x4 flash Stock 2002 - 2005 Explorers 3
Similar threads
