terrapin69
- July 23, 2013
- 2003 Ford Explorer
Finally got the alignment and steering wheel issue sorted out after four trips back to dealer - Great! Soon as I pulled off the lot, within an hour or so, the ABS light pops on. Brought it back and at the location I visited (they have 2), they only have a generic scanner which reads the left sensor. According to them, they replaced the right wheel bearing - Ok. When the tech drove the car with the code reader attached, the issue was intermittent - On and Off.
Any ideas guys/gals? Seems like too much of a coincidence that this light is on immediately after they did work. By the way, their other location, with the "real" code reading tools, is booked through next week.
Any DIY guidance would be appreciated - If I remember correctly, this happened before and I order a sensor from Amazon, installed myself in 30 minutes - Problem solved.
Thanks
Thanks
