kedmondson1970
- April 17, 2009
- Imperial, MO
- 98 Eddie Bauer
My ABS light came on some time ago and recently my neighbor brought over his ABS scanner and read the codes...RF speed sensor (don't recall the exact code itself). So today we went to work replacing not only the sensor but also the entire hub, since it was basically the same cost at Advanced Auto for the hub/sensor assembly as just the sensor.
Got it all done, started the truck...light still on. Checked the connection where the wire plugs into the harness under the front end (several times), seems tight, no bent pins. Tried to reset the code by disconnecting the negative battery cable for 20 minutes, still no luck.
Any suggestions? I've heard that only a Ford dealership can reset certain codes with their own scanners...is that true? We re-scanned again and it returned the same code...makes no sense since it's all brand-new.
Thanks
Kevin
Thanks
Kevin
