ABS sensor | Ford Explorer - Ford Ranger Forums - Serious Explorations
ABS sensor
Daveboys
Shelbyville, il
99 limited
The ABS light has been on in my EX for a while. I was reading on here about testing the sensors with an ohms meter. I just wand to verify a few things.
Are there 3 sensors? I belive there are 3 1 in each wheel bearing in the fron and one on the ring gear in the back. Is that correct?
If not where are the located?
Thanks
gucc
MA
2000 Mountaineer
I just change the rear sensor last weekend
:) I got the part from Napa. Only $8.95. I would check the rear one first. Mine was completely open when checked with a VOM. Easy to change but you'll need to jack up the rear end. Jack up the frame not the axle. The sensor is at the top of the differential.
