rocketboy52
- October 4, 2005
- Tehachapi, CA
- 95 XLT 4x4
I'm newbie to the AC world, but have spent the last two hours going through this AC forum. I have a better idea about the AC system from reading a bunch of Glacier's Posts (THANKS A BUNCH). Here's the deal:
95 OHV 4.0 Explorer w/ 130,000 miles. Recently moved out to Mojave/Tehachapi CA area. AC was working fine until two months ago. On a hot day, I turned on the AC and got only outside air temp (maybe even slightly hotter). I went to Autozone and bought a Quest R-134a refill can and cheapo quest gauge. Read the intructions on the can, turned the Car and the AC on and hooked up the can and gauge to the Low pressure service port. Instantly the Gauge pegged past 100psi in the red/danger zone of the gauge. Not sure I did everything right, I pulled off the can, and reread the instructions on the can. With the engine off, and refill can valve closed, I hooked the gauge to the low pressure side port again and read 95 psi. I'm not sure what this means so I searched for a post here to see if I could find out some more info. I don't believe my compressor is engaging, but I'm not sure.
With AC off, and in Park I idle just under 1000rpm. I turn on the AC and RPM rises to 1100 for a split second and then returns to 975. I don't here a click from the compressor. The only noise I can hear is my Air blower under the dash. I seem to remember when the compressor turned on in the past I heared a distinct click followed by a consistantly higher RPM. I'm not sure what my next move should be. How to tell if the compressor is shot, or the compressor clutch is shot?
I already have a nice vacuum pump (Robinar unit), and I am looking to buy a decent set of gauges next. After that, what should be the first thing I check? Should I check anything else before I reclaim the R134? What can cause the low pressure side to have such a high PSI? shouldnt it be in the 30-45psi range? Thanks in advance for all help
