AC blows cold when moving, but warms up when stopped?
jchristian79
Is this normal? 2005 Explorer, manual AC controls. Replaced blend door actuator 9 months ago, just pulled out the broken recirc door last week which had stopped the airflow. I sealed up almost all of the fresh intake vent from under the hood cowling too.
This issue has been happening since it's been warm enough to notice the need for AC. When the AC is on (both Max AC and normal) it gets nice and ice cold while moving, even at side street speeds it's fine. The moment I stop at a light or something, I notice it starts to get warmer. Then once I start moving, it cools off again.
I have already checked the refrigerant pressure and it tested ok at about 50 psi (it was about 95 out when I checked and that was the normal range for that outside temp).
The temps in Sacramento have been around 100-105 this week so I've noticed the temp difference between stop & motion a bit more this week. I've never had a vehicle do this before so I'm just curious if this is normal or if there's something going on I could check out? Thanks for any thoughts!
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
doug625
Location
Michigan
2002 XLS, 2007 XLT
a/c is not my area really but I would try sitting still in park and hold the engine rpm's up to around 2000 for maybe 30 seconds and see if the air cools then, if you haven't tried that already...then you'll at least know if it's related to vehicle speed or engine speed. Not sure if being low on freon could cause this or not. The engine turning the compressor faster could compensate for this.. again not sure but I would try this to narrow some things down. Someone else can prolly help more with more A/C knowledge.
rickybobby
Battle Creek, mi
'97 XLT
you need to know the high pressure too, the low side can be fine when the high side is too low and the system wont work right.
jchristian79
Hmm, good idea, I'll try that today.
Does that mean I need a larger pressure gauge to fit the high pressure side? Or is there another way to check it?
matt0248
Chicago
02 XLT V8
you need pressure gauges on the high and low side to know what is going on. most likely just a bit low on freon and the higher rpms and higher compressor cycling speed are able to compensate. Also air flow does play an important role, if the fan clutch is not operating properly or the air flow through the condenser and radiator is restricted with debris than the system will not work properly.
jghake
Washington
1983 F250 HD 4x4
I've noticed that mine is doing the same thing. Keep us updated as to what you find fixes it. I'm leaning towards mine being low on fluid.
Is it best to have a shop do it or is there some way I can fill it myself?
matt0248
Chicago
02 XLT V8
ideally you should have it evacuated and recharged with the exact proper amount of Freon. However, you can buy refill cans at parts stores that come with everything to just add some freon to your system.
jghake
Washington
1983 F250 HD 4x4
Do the cans work as well as having the system refilled? I just know the last time I looked into it (a few years ago for a different car) it was pretty spendy to have done. I elected not to....
rickybobby
Battle Creek, mi
'97 XLT
you need what is referred to as a "manifold set" it has 3 hoses, one for the low pressure port, one for the high pressure port, and a 3rd for the refridgerent can. You dont have to connect the 3rd hose to a refridgerant can to use it though, as there are valves for each hose. You can get this setup at harbor freight for right around $40 IIRC
Alan Morrison
Grafton, OH
2008 Explorer
In really warm weather, you should always use the recirc mode especially when stopped and idling. Another trick is to shift to neutral rather than leaving the trans in Drive. Using recirc mode greatly reduces load on the AC because hot outside air is not introduced to the vehicle. Shifting to neutral eliminates the heat generated by the trans clutch being partially engaged while waiting for the light to change. This heat goes into the trans fluid and must be dissipated by the trans cooler in the radiator increasing the heat load on the radiator. Neutral also reduces engine heat generated by maintaining idle speed with the trans load applied. If none of the above helps, check the fan clutch. If that's OK, have the radiator boiled out.
tower
Millbury, MA
03 Limited centennial
I would guess low charge or you fan clutch. I would have the fan checked because if it is starting to go this would be one of the first symptoms as it gets weaker very bad things will start to happen.
blueoval9erlifer
OAK HILL, KANSAS
04 explorer XLT
from what you say you might start by taking a garden hose and washing the condenser and radiator out really good, my buddy who does nothing but ac work in the summer says 90% of the people who come in because their ac is not working good could have saved 40 minutes of his labor by doing this will probably also see your temp gauge drop a little if its clogged.
the other part of this equation is that it is hard for the condenser to cool the refrig back down when it is this hot out. Almost every vehicle out there will have the ac warm up when at a stop if its getting up close to the 100 degree mark. last if there is still freon in the system then there is no reason to have it reclaimed sucked down and then put back in. whats the difference between adding new freon to your system or having a shop reclaim your freon and then put it back into the system. if you get the specs the guages should tell you the story.. if the high pressure is skyrockting then clean the condenser if low side is not right then put in or take out some freon. also if the high and low side do not equalize (shut the vehicle off with ac on) then probably have a clogged orifice.
B Defrost blows cold Stock 2002 - 2005 Explorers 0
N Heat blows cold air when stopped Stock 2002 - 2005 Explorers 24
0 Truck blows cold when I stop Stock 2002 - 2005 Explorers 10
B AC blows cold Heat blows luke warm Stock 2002 - 2005 Explorers 7
D Front-passenger & driver heat not working, only blows cold air Stock 2002 - 2005 Explorers 2
R Heater blows cold air Stock 2002 - 2005 Explorers 2
B Heater Blows Cold Air When Idling. Stock 2002 - 2005 Explorers 6
R AC Blows Cold Air On My Feet Stock 2002 - 2005 Explorers 3
L 2002 explorer: 5r55w intermediate servocap blows out AGAIN ! Stock 2002 - 2005 Explorers 2
P 2004 Explorer A/C Blows Only HOT Air-doors work, actuator's fine, freon full Stock 2002 - 2005 Explorers 0
H A/C Blows Hot Air - but nothing seems broken? Stock 2002 - 2005 Explorers 4
P 04 Explorer EB- 4.6 l Multiple panel Lights on-ABS,4x4 high/low,a/c blows warm Stock 2002 - 2005 Explorers 14
R Heat only blows while moving or once car is 100% warm Stock 2002 - 2005 Explorers 4
F AC Blows out all vents regardless of setting Stock 2002 - 2005 Explorers 6
H no revers lights and fuse blows Stock 2002 - 2005 Explorers 3
H no revers lights and fues blows Stock 2002 - 2005 Explorers 0
T AC blows on floor when on "face" setting Stock 2002 - 2005 Explorers 5
J Help with 05' ford exploer AC...It blows Hot! Stock 2002 - 2005 Explorers 2
A #41 fuse blows again and again. XLT 2002 Stock 2002 - 2005 Explorers 5
M air always blows even while off Stock 2002 - 2005 Explorers 3
D AC Blows through the floor Stock 2002 - 2005 Explorers 10
J Rear console vent always blows hot air Stock 2002 - 2005 Explorers 2
T 2002 Sport blows emission fuse Stock 2002 - 2005 Explorers 2
K Rear A/C blows hot air!!!! Help Stock 2002 - 2005 Explorers 0
J Knocking noise after cold start Stock 2002 - 2005 Explorers 8
M Cold start 02 explorer Stock 2002 - 2005 Explorers 0
W Heater blowing cold air Stock 2002 - 2005 Explorers 2
R Heater blowing cold Stock 2002 - 2005 Explorers 1
KA3NXN Ac is cold out of some vents but warm air out of others. Stock 2002 - 2005 Explorers 2
S Explorer loud squeaking on cold start...SOLVED Stock 2002 - 2005 Explorers 3
A Cold air intake and k and n air filter? Stock 2002 - 2005 Explorers 4
C Ford Explorer 2002 - air blowing in AC is not cold Stock 2002 - 2005 Explorers 0
W 04 XLT cold air intake ideas Stock 2002 - 2005 Explorers 9
J Won't Start When Cold Stock 2002 - 2005 Explorers 6
J cold weather start, or lack of Stock 2002 - 2005 Explorers 12
firefly1246 Dual Zone A/C randomly stops being ice cold Stock 2002 - 2005 Explorers 0
J 2005 Mountaineer Dual A/C Issue (Warm Drivers - Cold Passenger) FIXED!!! Stock 2002 - 2005 Explorers 4
G 2002 exploder xlt cold no start problem Stock 2002 - 2005 Explorers 27
J 2004 4.0L Cold start issues Stock 2002 - 2005 Explorers 3
Z 03 4.6 V8 Idles rough in cold weather, no drivability issues. Stock 2002 - 2005 Explorers 10
R HELP! It's getting cold, I need more heat! Heater issues! Stock 2002 - 2005 Explorers 2
R 2002 Explorer XLS Air Conditioning Not So Cold Stock 2002 - 2005 Explorers 14
J cold start up flare Stock 2002 - 2005 Explorers 12
D No power when cold Loud sucking sound Stock 2002 - 2005 Explorers 3
K Runs great when cold, power loss in closed loop, neg trims Stock 2002 - 2005 Explorers 16
6 Explorer 4.6, p1507 code, rough cold idle, SES light Stock 2002 - 2005 Explorers 2
M 2002 4.0 Lean when cold, Rich when hot, A real headahce Stock 2002 - 2005 Explorers 4
R Shifts fine when cold Stock 2002 - 2005 Explorers 2
A Ticking Sound when engine is cold 4.0 sohc Stock 2002 - 2005 Explorers 14
T Transmission only slips when cold Stock 2002 - 2005 Explorers 8
Similar threads
