JimW
- February 18, 2007
- Skaneateles, NY
- 97 Explorer
I have a 1997 Explorer (5.0L) and the AC compressor cycles continouously. The compressor will stay on for approximately 3 seconds and than turn off...the compressor will then turn on again ~ 4 seconds later and cycle again. I have put a gauge on the low pressure port and have added -1- can of 134 refrigerant...the pressure reading is ~ 45. I have shorted out the low pressure switch and can keep the compressor running continuously; however, it still cycles once I plug the low pressure switch back into the circuit. This seems to me to be a low amount of refrigerant; however, the the pressure reads at the full setting of 45...should I add more refrigerant to the system? Is it cycling because it is on the verge of being too low?
Any feedback would be welcome.
