BACKGROUND:
I was quoted $1600 for a shop to do the complete job or $325 for flush, vacuum and recharge only. I found it difficult to get a quote from a shop for just an AC flush. Most shops normally do it as part of AC repair and not just a stand-alone job. This motivated me to see how hard it would be to rent some tools and do it on my own. I stated before that I don't have access to “shop air”, but I actually do have a small 1 gallon (100 psi max) air compressor. I wasn’t sure if it would get the job done, but it did just fine. It was constantly refilling due to its small capacity, but it worked. I bought some additional accessories (blow guns, moisture separator, connectors, etc.) for this job, but I know I will use them again in the future. The flush proved useful. I only found a few metal shavings, but a lot of other debris got flushed out of the lines.
Total DIY cost was about $700 (Motorcraft parts) including tools purchased.
RESOURCES:PARTS REMOVAL:
Removed drive belt, air intake assembly, battery, etc to gain access to the AC system components.
Removed the front Orifice Tube from the Condenser to Evaporator line to assess the damages. Compressor gave no previous warning signs of damage (noises). Appeared to be an instantaneous failure with minimal amount of metal collected.
Removed the Expansion Valve from the Rear Evaporator to assess the damages. Appeared to be a minimal amount of metal collected.
Removed AC Manifold Line connections from Compressor, Condenser and Accumulator
Removed AC Manifold Line Brackets from the bottom of the vehicle to allow for free movement (but not removal) of the line.
Removed Condenser to Front Evaporator (Hi Press) line connection from Condenser.
Removed Front Evaporator to Accumulator (Lo Press) line connection from Accumulator.
Removed Rear Evaporator to Accumulator (Lo Press) line connection from Accumulator AC Manifold line.
Removed Condenser to Rear Evaporator (Hi Press) line connection from Rear Evaporator.
Removed rear Evaporator to Accumulator (Lo Press) line connection from Rear Evaporator.
Did not remove any line connections that required special tools (metal o-rings).
Removed Accumulator.
Removed Compressor.
Removed Condenser.
FLUSHING:
- Rent AC Flush Kit from Auto Zone = Free
- AC Flush (32oz) = $15
- Compressed Air with moisture separator, tire chuck, rubber-tip blowgun
- Flush Catch Container = DIY
Back flushed (4oz) Condenser to Compressor (Hi Press) line. Line blown with compressed air to dry.
Back flushed (8oz) Compressor to Accumulator (Lo Press) line. Attempted to flush as found, but had to move the Accumulator side of the line below the car to get good flow and a decent flush. Line blown with compressed air to dry.
Back Flushed (8oz) Rear Evaporator (Hi Press) line to Condenser. This was done with the connection around the Orifice Tube disconnected and capped (zip tie and a rubber glove). The Condenser line connection was placed below the front of the car to get good flow and a decent flush. Line blown with compressed air to dry.
Back Flushed (8oz) Accumulator (Lo Press) line to Rear Evaporator. Line blown with compressed air to dry.
After a lot of searching and evaluation of the situation, I decided NOT to flush either the Front or Rear Evaporators. Apparently, it is near impossible to flush an evaporator and get it completely dried out while it is still installed on the car. From what I found, the amount of oil (which may or may not contain debris) in the evaporators is minimal (3oz total).
Added a small amount of flush the hi press line going in the Front Evaporator and blew air through the low pressure line. Line blown with compressed air to dry.
Added a small amount of flush the lo press line coming out of the Front Evaporator and blew air through the hi press line. Line blown with compressed air to dry.
REINSTALLING PARTS AND LINE CONNECTIONS:
- PAG 46 Refrigerant Oil with Dye (8oz) = $11
- AC o-ring kit = $13
- Measuring cups (ability to measure 1oz increments)
- System refrigerant oil capacity = 13oz
Added 1oz of PAG 46 Refrigerant Oil with Dye to the input of the New Condenser
Installed New Condenser
Removed 7oz of Refrigerant Oil from New Compressor
Added 7oz of PAG 46 Refrigerant Oil with Dye to the input of the New Compressor
Installed New Compressor
Added 2oz of Refrigerant Oil (from New Compressor) to the input of the New Accumulator
Installed New Accumulator
One at a time, each line was blown with compressed air to dry, o-rings (dabbed with plumber’s lube) were replaced and the lines were reconnected to each component. Ensured new o-rings were same size and thickness (or did not replace).
Installed rear Expansion Valve.
Installed front Orifice Tube.
VACUUMING AND RECHARGING THE SYSTEM:
- Rent A/C Gauge Set with Refrigerant Can adapter valve from Auto Zone = Free
- Rent Vacuum Pump from Auto Zone = Free
- R134a refrigerant (5 x 12oz cans) = $50
- Temperature gauge or Multimeter with temperature function
- System R134a refrigerant capacity = 56oz
Followed A/C gauge set directions to put a vacuum on the system.
Replaced drive belt, air intake assembly, battery, etc while vacuum pump was running.
Pulled a vacuum to 30in Hg for 30 min, closed all valves, allowed to sit for 30 min and checked for leaks.
Followed A/C gauge set directions for charging the system.
Placed a jumper wire on the low pressure sensor connector to engage the compressor.
Continued to look for dye colored leaks and listening for leaks.
Kept track of the lo side press, high side press and total amount of R134a added to the system (56oz max)
Used this chart as a general rule of thumb:
A/C CHARGING RESULTS:
R134a Can - - Ambient Temp - - Dash Temp - - Lo Side Press - - Hi Side Press
#1 - - - - - - - 94 deg F - - - - - 99 deg F - - - 10 psi - - - - - - 125 psi
#2 - - - - - - - 94 deg F - - - - - 90 deg F - - - 45 psi - - - - - - 225 psi
#3 - - - - - - - 92 deg F - - - - - 66 deg F - - - 47 psi - - - - - - 235 psi
#4 - - - - - - - 95 deg F - - - - - 60 deg F - - - 44 psi - - - - - - 245 psi
#5 - - - - - - - 95 deg F - - - - - 57 deg F - - - 44 psi - - - - - - 260 psi
* For R134a Can #1 only half a can was used so the system capacity was not exceeded.
During test drive, dash temp dropped to about 46 deg F.
LESSONS LEARNED:
- Don’t forget to place a jumper wire on the low pressure sensor connector to engage the compressor.
- Inspect/use original o-rings to avoid leaks if exact size/thickness replacements are not available.
- R134a cans will empty quickly (1min) if there is a leak in the system. Normal empty time is about 10 min per can.
- ABS warning light may come on if ABS connector was disconnected during A/C repairs. This light will go off during your first test drive.
