sd_iconoclast
- February 17, 2012
- San Diego, CA
- 1991 Explorer
I have a '96 XLT with 5.0 V8.
When I bought it, the AC did not work and I decided to replace the whole system.
I got new Condenser, compressor, evaporator, orifice tube and hoses.
Compressor came with 7 oz PAG46 in it. I added 2 Oz PAG 46 to low side of accumulator. My under hood sticker says max capacity of R-134a is 1Lb, 14 Oz.
After evacuating the system, I added 1, 12 oz can of R-134. As I neared the end of the can, I say cycling on the gauges, even though the compressor clutch was not engaging. When I got to about the middle of the second can (18Oz total), the compressor clutch started to engage. I saw the low side would go from about 22-50 just like my book said. High side was about 100-140 and was going up. About when I finished the second can (24 oz total) the clutch stopped cycling. Now it is always engaged and the low side reading is about 35 and the high side reading is about 160 all the time. I did this in the rain at about 70 deg F. My interior thermometer says the AC air is about 52 degrees F.
That does not seem very cold. Is something wrong?
