AC help needed
gurnzb
2011 Ford Explorer
So long story short, AC is blowing warm.
I've attempted a recharge, didn't work. I noticed as I was recharging, the pressure would very slowly go down after I injected some R134a. Maybe I have a leak?
I want to check compressor, but don't know where it is. Thought I was looking at the right thing but too many belts for it to be compressor. Can someone submit a pic of their compressor? 2011 Explorer is what I have, so a 11-16 would work I'm assuming.
I also noticed the fan in what I think is the condenser was not spinning. Not sure if that is a by product of something else, or if it was even the condenser.
J 2000 Ranger AC help needed A/C & Heater systems - HVAC 1
K Heater control valve installation help is needed. A/C & Heater systems - HVAC 3
S A/C pulley removal help is needed. A/C & Heater systems - HVAC 4
S A/C freon recharging help is needed. A/C & Heater systems - HVAC 2
K New member Heater HELP NEEDED! A/C & Heater systems - HVAC 1
blueka Urgent Help Needed A/C & Heater systems - HVAC 3
M Rear ac line help 2012 explorer A/C & Heater systems - HVAC 1
D Help on my 1993 ford ranger XLT A/C & Heater systems - HVAC 3
W Need help, I'm lost A/C & Heater systems - HVAC 0
T Help wiring electric fan A/C & Heater systems - HVAC 5
E Need help identifying tube A/C & Heater systems - HVAC 0
F 2013 Ford Explore Cooling and Blower issue - HELP A/C & Heater systems - HVAC 1
R 08 explorer air conditioner help A/C & Heater systems - HVAC 10
C '97 Always hot air, NOT the blend door????? Please help A/C & Heater systems - HVAC 8
D fan clutch and fan 92 xlt help A/C & Heater systems - HVAC 10
S 96 limited Please HELP! A/C & Heater systems - HVAC 8
A Heat/AC--MAJOR ISSUE, please help. A/C & Heater systems - HVAC 0
J need help A/C & Heater systems - HVAC 0
A Ac help weird smell too A/C & Heater systems - HVAC 0
U Need help diagnosising AC issue (w/video) A/C & Heater systems - HVAC 2
M HelP! A/C & Heater systems - HVAC 1
N 2005 Explorer evaporator removal help A/C & Heater systems - HVAC 1
I A/C worked before they fixed my Explorer Help A/C & Heater systems - HVAC 1
N 02 blower and evap core removal help A/C & Heater systems - HVAC 0
V 2002 Ranger; Help Troubleshoot Why A/C & Heat Blows Thru Defrost Only - No Vents A/C & Heater systems - HVAC 2
T This doesn't seem right... Please help A/C & Heater systems - HVAC 3
B blower resister help?? plug connection A/C & Heater systems - HVAC 3
G help, blower only works on high. A/C & Heater systems - HVAC 4
I Need help for Winter. (Blower) A/C & Heater systems - HVAC 7
K Blowing Warm Air after A/C Recharge, please help! Edit: Updated with Video A/C & Heater systems - HVAC 1
J 99 explorer v8 no ac after dump !!! HELP A/C & Heater systems - HVAC 0
X Compressor On & Off, 140lb running pressure! Help A/C & Heater systems - HVAC 6
X Compressor On & Off, 140lb running pressure! Help A/C & Heater systems - HVAC 0
P I need some A/C help. A/C & Heater systems - HVAC 6
A I need help finding the 2002 Ford Explorer radio wiring diagram. A/C & Heater systems - HVAC 4
D Trying to Diagnose My Explorers A/C issues please help!!!! A/C & Heater systems - HVAC 3
S AC Problem's Please Help A/C & Heater systems - HVAC 1
K 02' A/C Help A/C & Heater systems - HVAC 4
W Need help with new A/C compressor kit A/C & Heater systems - HVAC 2
J pressure to high please help A/C & Heater systems - HVAC 9
G Had a bad day. need help on A/C (1993 Sport) A/C & Heater systems - HVAC 2
D Help,AC Compressor is discharging coolant A/C & Heater systems - HVAC 3
U 94 ford explorer, help A/C & Heater systems - HVAC 1
D Need A/C help. No idea where to start. A/C & Heater systems - HVAC 1
K Need some AC Help A/C & Heater systems - HVAC 7
davidhicks16 I need help trouble shooting asap A/C & Heater systems - HVAC 1
T 2000 ford heater will not work please help A/C & Heater systems - HVAC 5
G Help with heat. A/C & Heater systems - HVAC 4
D I have a weird problem, and need help with my 2003 Explorer A/C. A/C & Heater systems - HVAC 8
C I need help please! A/C & Heater systems - HVAC 5
Similar threads
