AC Help. working in engine compartment but not making it to cab.
Zigfreed
Erin Ontario
2004 Explorer Sport Track
Hello,
I have been worki g on my 2004 ford explorer sport trac for days now and have fully redone the ac system under the hood but am still receiving no cold air in cab. As the title said, I have co firmed that the ac is in fact working in the engine compartment properly 43-47f but its not making its way into the cab. I have also checked the heat/ac blend door motor and it seems to be working. Is there any other components that would cause an issue like this?
Any help would be apriciated! Thanks in advance.
ace7183
nj
03 ford sport trac
only thing i can think of to check would be the blower motor, resistor, or blower motor relay
Zigfreed
Erin Ontario
Yeah I have recently replaced both the blower and the resistor and they both seem to be working(fan works).
koda2000
x
Just because the blend door actuator motor works, it doesn't mean the blend door is moving. Do you get heat?
