762mm
- July 13, 2004
- Canada
- '99 XLT (4x4, SOHC)
Hello,
I have a 99 XLT SOHC and today, after a radiator/overflow tank drain & refill with new Prestone mixture, I noticed that my heater doesn't work anymore... All I get is cold AC air blowing out the vents no matter where I position the temp gauge (cold/hot) or the vent setting knob (the vents seem to work well though, and I can switch between AC and MAX AC, but that's all that's available).
I ran the vehicle for about 15 minutes on idle and with the heater on the max position before noticing that (in order for new coolant to enter the system). If you would happen to know what this might be, please let me know... I read about the blend door problem, but since my AC works fine (and it's the only thing that works), I guess it might be something else. Any input would be greatly appreciated, thanks in advance.
