ac problems | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership! If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
ac problems
bhowes1
06 explorer rsc
I just bought my wife a 06 explorer rsc and I have noticed that when we run the ac it fluctuates between blowing from the front vents to the defrost vents. Ac blows ice cold you can still turn the speed of the fan down. Tried doing different combinations of things and it still wemt back and forth between the vents. Any help would be greatly appreciated!
Holiday Special! Join the Elite Explorers $20 for 2 years! Gets rid of the ads!
Flag Gibby
Flagstaff, AZ
2006 Mountaineer AWD
bhowes1
06 explorer rsc
Is there directions or a forum on how to change the temp blend door?
bhowes1
06 explorer rsc
Im an idiot I read the wrong part lol so would it be the air inlet door?
nleipziger
Langhorne, PA
2006 Eddie Bauer
No, no, no! Probably not a blend door! Search this forum for the vacuum check valve located in the engine compartment. It's cheap to replace, under $15. Also a possible vacuum canister problem which is located behind the glove box.
Flag Gibby
Flagstaff, AZ
From post #5 in the link I provided, check part number 18 (the ATC solenoid and manifold) and then trace port #0 out for a vacuum leak if no issues with part #18 which I believe leads to the vacuum check valve as mentioned in the above post. Your symptoms seem to indicate fluctuating/low vacuum levels that are keeping the doors from staying in one position.
bhowes1
06 explorer rsc
Thanks flag gibby I will definitely take a look into it! Thanks for your help man
