Accx4
- September 14, 2006
- Phoenix, AZ
- 1995 Sport
Just picked up an '04 xlt. The heat works and the blower works but the AC is producing nothing if not slightly hotter than ambient temp. After a run on the freeway for a bit, the temp is barely cooler than ambient. The fan sounds like is should be pushing way more air than it does but that may just be the fan noise on high. I pulled the glove box and both actuators are functioning. As well, the temperature change from AC to Heat to AC etc. is noticeably different so I know the blend door actuator is functioning (though I can't verify if it is making its full travel so I can't rule out the blend door being partially open to the heater core. On my Cadillac, the OBD2 will give climate control readings. Apparently the Explorer doesn't? Suggestions? Thanks.
