I have a 1999 Ford Explorer with the 5.0 V8, purchased it used and did more work than it was probably worth.
However, the A/C WAS blowing slightly cool air, appeared to be overcharged, the compressor just kept cycling on and off.
I called a local shop and they told me to use a screw driver and let the freon out and see if the cycling stopped, if so, just add the right amount.
Well since I followed their instructions, it only blows HOT air, even after adding a partial can of 134. About a fourth of the can appears to be overcharged.
Could it be a bad drier/accummulator or orfice tube, possibly both? Would a bad compressor even cycle on and off?
Should I just take it to a reputable shop and quite playing mechanic?
