Justin5150
- December 9, 2017
- Mississippi
- 1993 explorer eddie bauer
93 v6 explorer. Idles fine, starts fine, seems normal. Under light acceleration, 1/4 throttle or so, there are no problems. If you push harder, 1/2 to full throttle, it falls on its face then accelerates again, just exactly like if I were to push the pedal to the floor and let off as if I were tapping my foot to a steady beat. It will continue to do so until you actually let off of the pedal. Then, it proceeds as if nothing happened as long as you don't push the pedal as to the point it started "jumpimg".
Now, sometimes shutting it off and restarting after a short bit makes it more drivable, sometimes not. It does it cold, warm or hot. There are no codes and the cel doesn't come on when this occurs.
Does anyone have an idea of what could be causing this?
