Access thru the firewall?
hatris
2014 Explorer
I have a 2014 Ford Explorer Limited that I am prepping to tow behind a motor home. I am installing a brake controller that requires running a small vacuum line and a couple of wires from the engine compartment thru the firewall to run near the brake pedal. Any body have any suggestions for access - so far, I have not found an easy access hole - Thanks.
Join the Elite Explorers for $20.
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve II
Callsign
VE3
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
I hope yours is not 4wd...
Sgt1411
VanBC/GoodyearAZ
2017 Explorer SPORT
The Police Modifiers Guide for upfitters is on the website www.fordpoliceinterceptor.com
It shows where Ford recommends going through the firewall.
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
Yes - it is a 4wd....why?
Unless it will be on a trailer (all 4 tires), you will run into a lot of issues. The Explorer has to be in accessory mode while towing because of the AWD system. Accessory mode will kill your battery if you do not start it every few hours.
Lots of discussions on this issue. If you were 2wd, you would not have to worry.
I remember one member hooking some type of trickle charger up while towing to combat the battery draining. Regardless, a PITA because it is technically an AWD system which requires the electrical system to be on.
Portland, ME
2013 Police Interceptor
I have a 2013 Interceptor Utility
I've tried running wires for my offroad LED's through the designated spots on the upfitter website, but am not able to locate the points they are speaking of under the glovebox, and am wondering if these holes have just been sealed up.
What would be the path of least resistance if I were to drill thru the firewall to run a cable or set of cables?
jaster
Texas, New Mexico, Mexico Border
05 ST XLT, 16 Exp XLT
Callsign
K5JSK
So, I need to access the battery of my 2016 Explorer from the interior cabin. I have been under the drivers dash for 20 minutes with a flashlight looking for access through the firewall. It's great that ford took the care to nicely seal the cabin, but.....is there any way to get through the firewall that I am not seeing? All my other vehicles had an access plug, wire harness with extra space that I can slide a wire through, or some way into the engine compartment. This Explorer seem to be tightly sealed. Any ideas?
PlatinumOwner
2016 Explorer Platinum
Just a note for Explorer's: these cars have a battery management system so be sure to connect the ground to the car frame, NOT the battery. Otherwise the battery discharge rate will not be in sync with the BMS. On another note, power is also accessible from the fuse box under the steering wheel column.
jaster
Callsign
K5JSK
peterk9
Staff member
Moderator
Callsign
VE3
Thank you.
You say you have a 2016 but your profile doesn't indicate that. Please update your profile with the requested "trim level" (Base, XLT, etc.) so it shows in the margin. That is useful info to have at times. Thank you.
IzzyEng4
Ansonia, CT
2014 Explorer XLT
Callsign
K1JJN
Hi all,
I'm replacing my 2008 Mountaineer with a 2014 Explorer XLT. Since I am an amateur radio operator and a firefighter, I am looking for help with locating access points / grommets on the firewall from the cabin of the truck to the engine compartment. I'll will be running a power and ground line from the cabin to the battery, as well as antenna coax to the front cowls.
I know I can hook up through the fuse panel but I rather keep the radio equipment on it's separate circuit / fuses for obvious reasons. Also for the antennas, I have the sunroof option so I'm limited with mounting an antenna on the roof at this time.
Any information and advice is greatly appreciated. Also if you have similar set ups (scanner, two-way radio) with photos that would be appreciated also.
Thanks.
Sgt1411
VanBC/GoodyearAZ
2017 Explorer SPORT
Hi all,
Thanks.
Ford Police Modifiers Guide shows the recommended grommet to use.
https://www.fleet.ford.com/truckbbas/topics/2012/modGuide.html
peterk9
Staff member
Moderator
Callsign
VE3
Hi all,
Thanks.
Welcome to the 5th generation Forum.:wave:
Your thread has been merged with this existing one. Here is also a thread you may find of interest.
http://www.explorerforum.com/xenforo/index.php?threads/any-2011-ham-radio-guys.328688/
73's Peter
IzzyEng4
Ansonia, CT
2014 Explorer XLT
Callsign
K1JJN
Thank you all. Hopefully when I get everything done, I'll post some pictures
denbig
2014 Ford Explorer Sport
Aftermarket sound system for 5th gen
which part of the firewall do i run a 0-4 gauge power cable through?
peterk9
Staff member
Moderator
Callsign
VE3
Medic531
Moore, Oklahoma
2019 Explorer 4x4 XLT
Hey guys not sure which forum to post this in so if this is in the wrong spot please move it.
Since my last explorer was totaled and I have a new one I need to get a radio, inverter, cell amp installed. The main issue for me is how to get power from the battery into the cab of the vehicle. I have hear you cannot go thru the firewall anymore for anything. I would like the stuff mounted under the rear seats or in the cargo area. If I can just figure out how bring power to inside the vehicle i'll be good. Any ideas?
