Add a leaf questions | Ford Explorer Forums - Serious Explorations
tootall_54
Worthington,IN
92' XLT
Alrite boys needin a little help on this one the rear end of my x is sagging pretty common from wat I have see and heard of lookin into the whole add a leaf to help the problem with doing this I have been told that you would also have to buy new shackles is this the truth or wat???? Also would I have to buy new U bolts for the leaf spring pack
No need for new shackles that I know of. You need a new center bolt. U-bolts depends on how much room you have.
As I see that no shackel just a center bolt and possibly new U-bolts would the AAL come with new center bolts if not wat size would they happen to be?
The center bolt is 7/16th IIRC. Some aal's are drilled for 3/8 and come with a spacer and 3/8 center bolt. You need to contact the aal supplier to see what it comes with.
