Hi i have a 2001 sport trac and i have a 3" body lift, tt, shackles, 3" spindles, add-a-leaf, and my front is about a 1"1/2 taller then the rear. Can i just add another add-a-leaf to lift it more? Or what can i do to lift the rear more cheap!! thanks
ya you could pack another leaf in there if you want to lift it but you will also be stiffening the ride...thats the cheapest way....or you could lower your torrsion bars an inch(i don't know what size tire you're running)...personally i would take off the shackles and aal and your stock springs and go with a bigger leaf pack this is the best way to do it for both ride quality and long term effects...i know you can buy the superlift rear springs(4") seperately from the rest of the kit and they are around $150 each which isn't bad(try 4 wheel parts or an equivalent)...aal would be most cost efficient but make it real stiff or you could spend a little more on new springs now and be happier in the long run
