mrdot
- July 27, 2016
- 15 & 16 EXP Int. 3.5T
Add Intelligent AWD gauge and engine/idle hours to civilian Explorer 13-16! Interceptor 13-16 AWD!
** This is the route to go for these modifications! don't buy any hexed .ab files from online vendors. The Ford dealers will not apply them most of the time and it will end up costing you their hourly rate! **
This can be done using FORscan: (you will need to register and get extended license)
The features to enable are build into FORscan. No manually modifying or dealer programming!
http://forscan.org/download.html
OBDLink MX Bluetooth Scan Tool:
https://www.scantool.net/obdlink-mxbt/
and a bluetooth enabled laptop.
Please report back with your results if you try this! ** Police models do not disable idle hours may reset counter **
Civilian engine/idle hours starts "0" when enabled.
Ford Service Manual Description of the AWD Gauge:
The AWD gauge displays the level of power applied to each wheel.
The following inputs to determine the AWD gauge display:
wheel torque data
AWD lock torque
engine rpm data
speedometer fault
As power is applied to the wheels, the area directly in front of each displayed wheel begin to fill in. The lowest power displayed is the closest to the wheel. As the amount of power sent to the wheels increases, the area fills in either forward (front wheels) or rearward (rear wheels) of the wheels.
wheel torque data
AWD lock torque
engine rpm data
speedometer fault
