hrbib21
- December 19, 2002
- Myrtle Beach, SC
- '99 Limited 5.0
I am trying to add an amp to the factory system on my 99 Explorer Limited. I am rather frustrated at this point. I have the amp wired up properly (power, remote turn-on, ground) but CANNOT get the speaker wiring right. Originally I plugged into the left rear door speaker and used the high level inputs on the amp. Didn't work. Next, I bought a high level to rca converter and that isn't working. From what I understand, the factory amp is part of the head unit. Is this my problem, the amps cancelling each other out? I tried to find the speaker wires going into the rear factory amp and sub (I know this is on the passenger side by the rear wheelwell) but I can't seem to get the torx bolt off for the seatbelt so I can't get the panel off. I do know where the wires are under the seat (the ones that lead to the factory amp/sub in the rear) but I don't know which are the speaker wires. I also know I can get an amp bypass harness but will it work if I am keeping the stock head unit?
HELP! Basically, what's the best way for me to add an amp and sub to the factory system?
