Adding aux power to inside rear of vehicle?
Medic531
Moore, Oklahoma
2019 Explorer 4x4 XLT
So it looks like the shop im talking to has been lacking in communication with me for five weeks and I have almost lost all confidence in them. I will likely attempt this on my own but need some suggestions or guidance.
I have a 2019 ford explorer xlt and need to bring power from the battery to the rear of the vehicle. I do not want to mess with a tiny pass thru hole in the firewall behind the glove box. My last explorer the shop went from the battery thru the engine compartment and under the vehicle then drilled thru the floor into the vehicle. I am needing at least two lead wires to go from the +batt terminal to under the third row seating area. Everything else should be easy to do but never drilled thru a vehicles floor before. Suggestions? Tools? Types of metals I would be drilling thru?
Thanks for the help !
Kenny
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve
Callsign
VE3
The 2011 XLT had a rear power point. Surprised that the 2019 doesn't.
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
There has to be power to the rear. I would run wiring from the nearest DC power plug and add a new plug wherever needed. I did that with my 1994 Explorer in the cargo area. It works best because its already fused and you don't have to drill any new holes through the firewall.
If you are committed to running a separate wire from the battery to the rear, then..
Why do you need two wires from the + side of the battery? Just run one heavier gauge wire to the back and split it to what you need.
Need to fuse or put in a relay near the battery, depending upon your expected amp draw.
What are you planning on powering up with the wiring?
What kind of amp draw are you expecting?
I would always chose to run a wire through the firewall and down an existing wiring harness to the rear. Its easier, the wire is less likely to sustain damage, and you don't have to figure out how to run it around all the stuff under there that melts wiring.
Medic531
Moore, Oklahoma
I will likely use one wire going from the battery to a terminal ill put in the back then hook everything else up to that terminal. I need to power inverter, communications equipment and switch box.
I dont think power from a 12v cig lighter will work. I need heavy gauge wire.
I have zero ideas on how to get thru the firewall on these newer vehicles. From what I understand its next to impossible to get thru using existing wiring as they are apparently all heavily sealed up as they should be. My 2015 explorer had to be done with the wiring under the vehicle and thru the floor for this reason.
ltdan84
Liberty Hill, TX
2016 Explorer Sport
Hey old thread, you've probably already driller your holes, but just in case you haven't...
Use an appropriate sized grommet to prevent chaffing of the wire insulation, and then seal the wire with silicone if going through the floor to make sure you don't have any exhaust fumes seep through. You could also drill a hole through the firewall and seal it the same way, then run the wire under the trim. What are you adding that needs so much power, an audio amp?
ElectronFlow
Ever Have The Feeling You're Being Watched??
Georgia
2013 Explorer PIU 3.7L NA
@Medic351
How did your project turn out ?
Itdan84,
He wanted to run a power inverter at the third row seating.
B 2015 FPIU - Adding a second battery Modified 2011- 2019 Explorers - Tuning & Mods 1
A So I decided to just keep adding horns. and more horns... Modified 2011- 2019 Explorers - Tuning & Mods 14
K Adding Recovery Hooks on 5th Gen? Modified 2011- 2019 Explorers - Tuning & Mods 13
kaotikgood Adding 'SPORT' logo to Weathertech liners Modified 2011- 2019 Explorers - Tuning & Mods 6
S Adding Intelligent Access to rear doors Modified 2011- 2019 Explorers - Tuning & Mods 0
D Adding fog lights to 2016+ Base Explorer? Modified 2011- 2019 Explorers - Tuning & Mods 43
B Adding Switches Modified 2011- 2019 Explorers - Tuning & Mods 38
B Adding Flowmaster to 2014 Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 21
J Adding Auto Side Mirror Folding System Modified 2011- 2019 Explorers - Tuning & Mods 27
H Options on adding an Auxiliary Input Modified 2011- 2019 Explorers - Tuning & Mods 15
N Adding Side Mirror Turn Signals Modified 2011- 2019 Explorers - Tuning & Mods 7
P Adding OEM Class 3 Trailer Hitch? Modified 2011- 2019 Explorers - Tuning & Mods 3
G Adding a turbo to the 3.5l Modified 2011- 2019 Explorers - Tuning & Mods 10
A Adding "Automatic headlights"? Modified 2011- 2019 Explorers - Tuning & Mods 1
P Feasibility of adding heated mirrors Modified 2011- 2019 Explorers - Tuning & Mods 26
A Adding Remote Start Access Modified 2011- 2019 Explorers - Tuning & Mods 105
1 Adding dashcam. Any tips? Modified 2011- 2019 Explorers - Tuning & Mods 126
D High beams after adding HID's Modified 2011- 2019 Explorers - Tuning & Mods 3
L Will adding magnaflow cause problems? Modified 2011- 2019 Explorers - Tuning & Mods 8
O Adding / Removing Dash Trim Modified 2011- 2019 Explorers - Tuning & Mods 23
K Adding a powered lift gate to an explorer Modified 2011- 2019 Explorers - Tuning & Mods 14
N Adding Fender Vents Modified 2011- 2019 Explorers - Tuning & Mods 40
J Adding Sync to base explorer Modified 2011- 2019 Explorers - Tuning & Mods 32
R Adding Autolamp to 2012 Base Explorer Modified 2011- 2019 Explorers - Tuning & Mods 2
F Adding Garmin SatNav - Hide the power cable Modified 2011- 2019 Explorers - Tuning & Mods 12
K Adding Mods to Explorer- Base Model Modified 2011- 2019 Explorers - Tuning & Mods 5
S Adding Portable XM Radio Modified 2011- 2019 Explorers - Tuning & Mods 0
R Adding a backup / rearview camera Modified 2011- 2019 Explorers - Tuning & Mods 61
D Adding the 110 outlet on the second row console Modified 2011- 2019 Explorers - Tuning & Mods 4
R Adding DVD and ambient lighting to XLT Modified 2011- 2019 Explorers - Tuning & Mods 18
S Adding Homelink Garage Door Opener Modified 2011- 2019 Explorers - Tuning & Mods 143
F Aux Driving Lights - switch options Modified 2011- 2019 Explorers - Tuning & Mods 5
T Anybody added aux reverse lights like this? Modified 2011- 2019 Explorers - Tuning & Mods 13
Bobs2018Explorer Upgrading the single Power Point in the rear cargo area, to more choices Modified 2011- 2019 Explorers - Tuning & Mods 8
G Installation of Power running boards on my ford explorer 2015 XLT Modified 2011- 2019 Explorers - Tuning & Mods 4
N More NA power coming! Modified 2011- 2019 Explorers - Tuning & Mods 29
SurrealOne Odd engine power RPM surge problem Modified 2011- 2019 Explorers - Tuning & Mods 10
1 How to get power that the battery saver can turn off Modified 2011- 2019 Explorers - Tuning & Mods 0
E Eco Power Parts updates Modified 2011- 2019 Explorers - Tuning & Mods 4
E Updates to Eco Power Parts and new shop! Modified 2011- 2019 Explorers - Tuning & Mods 5
T More power for 3.5 Modified 2011- 2019 Explorers - Tuning & Mods 5
E Unleashed Explorer Sport Power Package Stage 1 Modified 2011- 2019 Explorers - Tuning & Mods 56
F Power AMP Wiring Path - interior routing Modified 2011- 2019 Explorers - Tuning & Mods 1
E Powerpoint power Modified 2011- 2019 Explorers - Tuning & Mods 4
B Power Seat Switch Aluminum Dress-Up Kit Modified 2011- 2019 Explorers - Tuning & Mods 3
Q Where's the Power At? Modified 2011- 2019 Explorers - Tuning & Mods 20
I HELP! Need 12V accessory power Modified 2011- 2019 Explorers - Tuning & Mods 8
S 2011 Explorer amplifier power cable routing. Modified 2011- 2019 Explorers - Tuning & Mods 36
E Canvasback cargo/seat covers - power fold problem Modified 2011- 2019 Explorers - Tuning & Mods 3
W How I got accessory power without tapping into the fuse box. Modified 2011- 2019 Explorers - Tuning & Mods 8
Similar threads
