Adding One Touch to rear windows 2018 Explorer Sport?
SoCalHarley
San Marcos, CA
2014 Ford Explorer XLT
Is it possible to add One Touch to the rear windows of my 2018 Explorer Sport? I am familiar with aftermarket modules such as AutoLoc but wanted to see if the OEM system used in front windows could be added to rear and then controlled with Key Fob as part of the Global Window opening function. Thanks
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
I believe this has come up before but I'm not able to find anything on it nor can I recall what the answer was. Just guessing that you may have to change the rear window motors. I don't know if different wiring is required but likely some programming would have to be done. :dunno:
Not much help I know but hopefully someone with a little more insight will reply. Stay safe.
SoCalHarley
San Marcos, CA
Thanks Peter. I did just purchase the ForScan program and ELM327 device so programming will not be a problem. I am really surprised there is no One Touch on the rear windows. Curious if any 5th Gen explorers have One Touch on the rear windows. Probably should have checked into this as well.
peterk9
Staff member
Moderator
Callsign
VE3
As far as I know, the One Touch on the rear windows is not a feature of the 5th gen Explorer. My 2017 Platinum did not have it. The 2020 Explorer also does not have it. Out of curiosity, I just checked my Aviator and it does have One Touch on the rear windows.
SoCalHarley
San Marcos, CA
Interesting that your new Lincoln has it and none of the Explorers do not. Guess it comes down to cost. Curious what is different between the parts/wiring on the Explorer and Lincoln. I would be open to using the aftermarket modules on the rear doors but I don't think they would work with the Key Fob function.
bill32399
Oregon
15' Explorer PIU
Looking at the wire diagrams it is different. New motor, switches and door wiring would be necessary. It is very possible though looking at the schematics.
V Adding Nav to My touch what is needed? 2011-2016 My Ford Touch / In Vehicle Technology 10
I Adding navigation, need help with media hub. 2011-2016 My Ford Touch / In Vehicle Technology 0
T '16 Sport--Adding 401a package options aftermarket 2011-2016 My Ford Touch / In Vehicle Technology 1
1 Adding Keyless Entry Keypad and Mating it to Vehicle? 2011-2016 My Ford Touch / In Vehicle Technology 3
J Adding Back Up Camera - It can be done on the OEM screen 2011-2016 My Ford Touch / In Vehicle Technology 4
F Adding Android/iOS Mirroring to MFT 2011-2016 My Ford Touch / In Vehicle Technology 2
P Adding Sirius after the fact? 2011-2016 My Ford Touch / In Vehicle Technology 12
H Adding Bluetooth..? 2011-2016 My Ford Touch / In Vehicle Technology 9
K Ford adding Facebook features to Sync 2011-2016 My Ford Touch / In Vehicle Technology 8
T Adding Navigation Later 2011-2016 My Ford Touch / In Vehicle Technology 225
S MFT - Adding single contacts to phonebook 2011-2016 My Ford Touch / In Vehicle Technology 0
BobbyMarks THIS IS LIKE BEATING A DEAD HORSE, but any info regarding any updates on My Ford Touch? 2011-2016 My Ford Touch / In Vehicle Technology 7
J Touch screen not responding 2011-2016 My Ford Touch / In Vehicle Technology 10
B MyFord Touch help fix 2011-2016 My Ford Touch / In Vehicle Technology 1
1 HELP! Capacitive Touch Sensor / FCIM 2011-2016 My Ford Touch / In Vehicle Technology 6
N MY ford touch black screen again! 2011-2016 My Ford Touch / In Vehicle Technology 2
K Touch screen intermittently not responsive and backup camera issues 2011-2016 My Ford Touch / In Vehicle Technology 4
T MFT Screen touch points unusable 2011-2016 My Ford Touch / In Vehicle Technology 9
N My Ford Touch - 3 little quirks... is it fixable? 2011-2016 My Ford Touch / In Vehicle Technology 24
L 2015 My Ford Touch latest Sync software? 2011-2016 My Ford Touch / In Vehicle Technology 4
H Updating SYNC/My Ford Touch with a Droid or Iphone 2011-2016 My Ford Touch / In Vehicle Technology 5
V Touch screen not selecting what I am trying to select 2011-2016 My Ford Touch / In Vehicle Technology 12
R Factory MyFord Touch OEM GPS Navigation Upgrade Kit 2011-2016 My Ford Touch / In Vehicle Technology 11
W No touch screen beep 2011-2016 My Ford Touch / In Vehicle Technology 2
M My Ford Touch Problems- Software Update 2011-2016 My Ford Touch / In Vehicle Technology 13
B My Ford Touch 2011-2016 My Ford Touch / In Vehicle Technology 1
W Difference between 2011, 2012, 2013 My Touch/Sync systems 2011-2016 My Ford Touch / In Vehicle Technology 2
S MFT have no Touch 2011-2016 My Ford Touch / In Vehicle Technology 4
M Touch Screen Beeps 2011-2016 My Ford Touch / In Vehicle Technology 4
B My Ford Touch 2014 Sport 2011-2016 My Ford Touch / In Vehicle Technology 8
S U.S. driver safety group sues Ford over touch-screen systems 2011-2016 My Ford Touch / In Vehicle Technology 72
R MyFord Touch Suggestion (IVT Team) 2011-2016 My Ford Touch / In Vehicle Technology 1
gdecamp MyFord Touch Gets Better Voice Control 2011-2016 My Ford Touch / In Vehicle Technology 19
G MyFord Touch: Some Questions about hardware Directed at Ford's IVT team. 2011-2016 My Ford Touch / In Vehicle Technology 5
L 2013 myford touch voice recognition does not work with ANY contacts from my iphone4s 2011-2016 My Ford Touch / In Vehicle Technology 19
K MyFord Touch (Canada VS USA) 2011-2016 My Ford Touch / In Vehicle Technology 11
1 Nav-Tv MyFord Touch VIM module 2011-2016 My Ford Touch / In Vehicle Technology 11
P Playlists on USB - myford touch 2011-2016 My Ford Touch / In Vehicle Technology 22
D Good Review of the Ford Touch System 2011-2016 My Ford Touch / In Vehicle Technology 1
E MyFord Touch iPhone 4 Pictures 2011-2016 My Ford Touch / In Vehicle Technology 13
B MFT - MyFord Touch Update received at home 2011-2016 My Ford Touch / In Vehicle Technology 61
M MFT - MyFord Touch performance update 2011-2016 My Ford Touch / In Vehicle Technology 9
D I Selected Advanced for the MFT - MyFord Touch Voice Command Menu Setting 2011-2016 My Ford Touch / In Vehicle Technology 6
P MFT - MyFord Touch Sync2 First Poblem 2011-2016 My Ford Touch / In Vehicle Technology 15
B *OFFICIAL* MFT - MyFord Touch v2 Software Bugs and Fixes Thread 2011-2016 My Ford Touch / In Vehicle Technology 166
2 Freshly Installed MyFord Touch - MFT Performance Upgrade 2011-2016 My Ford Touch / In Vehicle Technology 45
D *OFFICIAL* I Received My MFT - MyFord Touch Software Thread. 2011-2016 My Ford Touch / In Vehicle Technology 126
1 MyFord Touch, MyLincoln Touch upgrades shipping this week 2011-2016 My Ford Touch / In Vehicle Technology 4
F A faster, simpler, better myford touch is here - MFT Update 2011-2016 My Ford Touch / In Vehicle Technology 859
K Ford Sync (Not My Touch) verison 3.1.1 2011-2016 My Ford Touch / In Vehicle Technology 1
Similar threads
