adjust timing on v-8? | Ford Explorer - Ford Ranger Forums - Serious Explorations
pufferfish
Baltimore
97 Mounty 5.0
before you say it, i searched and the words are too vague to come up with anything specific. so, yes, i probably has been discussed before but i can't find anything.
i was taking a look at the 5.0 in my mounty. it has a connector running out of where the distributor would be with the basic distributor clamp. is this where the computer reads crank/cam position for timing? if so, can it be loosened and turned to gain a higher base timing like a distributor can? if so, are there timing marks and a pointer and is there a spout connector?
Turdle
The Lowrider is a little higher
Staff member
Moderator
Humboldt, KS
2000 Mounty
Noooo!!!
Do not move this, it is the camshaft position sensor
It times the fuel injector pulses--ignition timing is determined by the crank position sensor--
Your best bet for achieving performance is a PCM flash or a chip. This is where the timing curve is adjusted---
dynamite196
Glastonbury, Connecticut
97 Sport
you need to do any tuning electronically.
pufferfish
Baltimore
97 Mounty 5.0
good to know! glad i asked! thanks!
Turdle
Staff member
Moderator
Humboldt, KS
2000 Mounty
