This is impossable right?
Hi so I sae this and thought it would be a good wasy to get exra tim ein determining why I have been running so rough lately. Which already started out bad when one of the bolts had seized up and broke partway any making, meaning I had to drill it out oh well Iguess I had the drill out anyways. but here's my question I took a look at the voltage of the tps twice to check and I got 4 volts now you said the normal is like just under , right (.97?) Is this big of a difference possabie and if it is that doesn't mean I need a new comp does it? i have also been running se;f diagnostics fairly regularly and I neve get any koeo codes mostly coninuous (yeah I clear them)the o^2 sensors been the main culpret mostly sayin mixtrue too rich (most of the time) It's relly rich I mean too lean so 0^2 clike you can smell the from like five feet awa yesterdy it it said too len the other two codes I get from the continuous test (and I aalways get both Are maf faults one sauing voltage too low the other saying too high. And then everyonce and a while I get con't control throttle , but I dod ajus tthe cab'e last night
