bmdubya1198
- September 17, 2020
- Charlotte, NC
- 2004 Explorer EB 4x4
I'm trying to diagnose an AdvanceTrac issue on my '04 Explorer. The codes that are showing are C1998 (I know, just needs to be calibrated) and C2777 (sensor cluster bus failure). I went ahead and checked over all the values for yaw and acceleration, both of which were zeroed out while sitting stationary on level ground. As expected. I also checked the wheels speeds while driving around the neighborhood, which were all matched up as expected. However, while driving, the yaw and acceleration rates did not change. I didn't make any aggressive maneuvers, but I'd think that there may be some small movement.
I installed Forscan (great software, by the way) and got it working with my ELM327 bluetooth adapter, and I'm able to read codes. Everything seems to be working properly. I tried to run an ABS IVD calibration, and it just says "service procedure interrupted" after 7 seconds from starting the procedure.
Now, I know the code is for a bus failure, which could be either the connector not seated well or the sensor cluster that has failed, but if everything else on my ELM327 adapter is working, could that have anything to do with this error, and I just need to get a different adapter?
Assuming that's all working properly, I'm thinking that I'll just replace the sensor cluster.
