dustinjorge
- March 6, 2009
- Seattle, Washington
- '95 XLT 4x4
I hate mounting relays under my hood without 'doing it right', so I spent some time down at pick 'n pull lurking around looking for the perfect relay box.
I'm wiring up my bumper lights (4 hella 500ffs) and in order to not have to cover 2 of them and still be legal here in WA, I needed a pretty specific circuit. The idea is to have 2 fogs on with the low beams and 2 driving lights on with the high beams, with that functionality toggled by the stock fog switch. Also, my switch panel will have an override that will illuminate all 4 at once.
So my circuit needed 3 relays and a diode... my search turned up this:
The box above holds any combination of relays and diodes up to 4 and came from an early 90s Aerostar (Driver side fender by firewall). I don't know which year, but when I went back to get a second one (too perfect) I noticed that some had them some didn't, so it was a matter of finding the right junker. Came apart pretty easily:
Now the problem is that I don't want to splice wires... so I need some connectors to snap in. Ford does not sell them, grrrr. After A LOT of looking around, I ended up at the Napa warehouse where I turned up these.
They're not a perfect fit but they're close enough to work very well... but the little 'bendy tab' is pretty flimsy. It likes to bend when pushing in the relay and that's no good. A little solder reinforced it just fine:
With that problem solved... now I need to make those pretty OEM style crimps on these connectors. I bought my crimping tool at Napa (overpriced), since I didn't feel like driving back to the warehouse if I couldn't find it elsewhere (Napa had 2 in stock in Western Washington).
The wiring done...
Added a pigtail from a <95 distribution box, some loom and friction tape, and it's ready to go...
I'm pretty damn happy with the result.
The wiring done...
