mowfixer
- November 30, 2008
- Sanford, NC
- 1999 Sport 2WD
My 99 OHV has been giving CEL only on very cold mornings. The truck runs smoothly even when cold and I am still gettin 21 MPG. Codes are lean bank 1,2. After reading this forum for a long time I went to check for an intake leak. I sprayed around the manifold when the truck was very cold. When I sprayed the base of the upper plenum I got an immediate change in engine speed. I tried sparying the lower intake area with no change in engine operation.
Here is my question. I do not have time right now to fix it myself even though it is an easy fix. I have taken it to two mechanics I know. One says upper intake gaskets (makes sense to me from symptoms above) and the other says since it is lean on both banks that all I need is an O2 sensor.
Do you guys believe I am right if I have the upper gaskets changed or am I missing something. I do not want to pay for work that is not needed as they want $125 to change gasket.
