Carguy3J
- June 21, 2008
- North East New Jersey
- '99 4dr. XLT SOHC A4WD
Ok, I've searched, and searched; both here and Google. I've never been able to find what I'm looking for.
A.) What are the Factory specs for a a 1993 Ranger 4x4?
B.) What should I REALLY be using, as the factory specs are probably not really the best for these TTB front-ends? I'm looking for some real-world, precise numbers, from people with actual experience/knowledge getting these TTB's right.
I don't have a "lift" per-se. But I do have upgraded HD 4-leafs in the back, and sort-of new (about 1-2 years on them now) coils in the front. The truck also came from the factory with 265/75/15's. Overall, I would say it does sit a bit higher then your average "stock" Ranger.
I do a LOT of high speed highway driving. I do depend on it in the snow,etc, but absolutely no "wheeling" or off-roading. I do use it frequently as basic transportation, with nothing in the back, but I also frequently load it very heavy.(1,600-1,700Lbs.)
I prefer a heavier, "tighter" steering feel (more + caster). I corner hard, and typically ask for .75 to 1.0 deg -camber, in all my vehicles. I still usually get a little bit of outside tire wear, as is the case with the Ranger currently.
The shop I have been using doesn't have anything this old in the computer, for specs, so they used a later E-150 van (???) They said that the computer wanted zero or slight toe-out. I disagree'd, and asked for a little toe-in. Any thoughts on this? My understanding is FWD vehicles get toe-out, as the FWD pulls the front tires in, under power, whereas RWD and 4X4 gets toe-in, as the front tires are "pushed" out a little going down the road. Thoughts? Numbers for recommended toe, in fractions of an inch and degrees please.
Thoughts on caster/camber splits?
I have Moog double adjustable bushings in the knuckle. They should have more then enough range to get the job done. Fixed, non-adjustable energy suspension radius arm bushing. (so no extra caster available there)
C.) I have read some posts about using "spacers" to even things out before going to the bushings. Not a lot of detail though. I assume this is referring to even the ride height, side to side. What is the target ride height? Where are the measuring points? Can't use the body/fender gap, as my body bushings are shot, and won't be changed anytime soon. What does one use for "spacers"? Under the spring seat, I assume?
