Aerostar "system too lean". Failed inspection.
houstondrummer
tomball,texas
'96 Ford Aerostar
My 1996 ,4.0 Ford Aerostar just failed inspection.
Paperwork stated "system too lean".
Purchased a year ago I replaced o2 sensor,plugs and wires.It was well maintained by previous owner.Where do I start
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
houstondrummer
tomball,texas
'96 Ford Aerostar
I do not have the computer hook up to check codes.I will head to "auto zone". They hook up and check it for free.I guess I could do a visual check on the gaskets.
BrooklynBay
Staff member
Moderator
Brooklyn, NY
houstondrummer
tomball,texas
'96 Ford Aerostar
Hello Again
I just found the paperwork from the failed inspection and it says :
" Fault Codes : PO 171 : System too Lean ( Bank 1 )
I don't know if this helps at all.
I will probably head down to the auto parts anyway to get the codes re - checked.
BrooklynBay
Staff member
Moderator
Brooklyn, NY
emerson
Prince George
'94&'97 Aerostar AWD
Hello Again
That's the same one I had. It turned out to be intake gaskets. I started a thread here about the job. It turned out to be not too bad; just time consuming. No issues since, except when you remove the hood, make sure after you put it back on to reconnect the ground wire and tighten on the stud on the passenger side inner fender. If you forget, your lights may do funny things.
