Aftermarket camber adjustment bushings for '91? | Ford Explorer Forums - Serious Explorations
GaryA
Does anyone know where can I can find some camber adjustment bushings that provide more adjustment range than the stock adjusters? My suspension is still stock. Which leads me to my next question. I am going to be doing a lift pretty soon, and the Superlift Supperrunner system sounds good, but I have read posts here about guys knocking holes in their front pumpkins with that setup. Doe anyone know if that problem has been fixed?
The stearing system isn't what puts holes in the diffs. Its the drop passenger side drop down bracket that does it. That has been fixed now you just have to make sure you get the one that is not a plate and looks identical to the one thats in there now just a longer arm for it.
Ryan Penner
1992 Explorer Sport Modified
Thanks Ryan. I keep hearing bad things about the 5.5" lift. What do you think? Have you had any alignment problems? What's the difference, other than height, between the 5.5 and the 4"?
Gary
I have not had to bad of problems with the alignment. I do use the truck off-road a lot so I have to get an alignment every 4 months or so. The only other problem I have had so far is breaking the radius arm. That was fixed in Moab with a quick weld up job. The newer radius arms are more beefy then the ones I have now so that probably helps out there. Its a good kit its just been well beta tested on the public which is why you hear bad things.
Ryan Penner
