Jdrii
- March 10, 2015
- 2005 Ford Explorer
I had a local mechanic replace a bad fuel pump in my 2005 Ford Explorer. There was a $300 difference between the aftermarket and the factory. I said we can go with the aftermarket. Well, the first time I filled the tank after having the fuel pump installed I noticed the gauge didn't go up past the *full mark (like it did before I brought it in). After a couple of times filling up it started bugging me that the gauge wouldn't show it's full, rather the gauge would show between 3/4s to full. I called the mechanic and asked why my gauge would show that it's full when I know the tank is full because it took just shy of 16 gallons. (Yes, I ran it down to Empty to test the tank size) The mechanic told me it's because I used an aftermarket pump and not a factory one. This doesn't sound right to me. Obviously I know little about vehicles, does this sound right or is it because now the fuel gauge isn't sitting correctly in my tank? Thank you in advance for responding. Your help is greatly appreciated.
