Joe Stewart
- October 10, 2018
- Location
- Austin, Texas
- Austin, Texas
- 2017 Explorer Platinum
You will need the usb hub for CarPlay to work, you will need the power pigtail that will go from the usb harness to the new hub. (There are 3 different pigtails, find which one goes to the 2016). You will need to purchase a gps antenna with fakra plug(the sync2 uses a different type and not compatible). The apim attached to the back of the screen will have to be programmed to your car. You will need a laptop snd the Program “Forscan”, purchase an extended license (program is free, license is 10.00). You will need to purchase an ELM327 adapter that reads both HS-CAN snd MS-CAN.
You can pay someone to write the values for you for around 60.00 (this is what I did, found his name on the forscan forum). You furnish your vin number, he will send you the file snd explicit instructions, very easy. Look up the video and YouTube how to do the whole remove and replace. You program, after all is back together. By the way, forscan can be used to do programming of many things. I got it initially to program new key fob, since I only had one. Their forum is great.
After you have it working, check your sync version and update. Many threads on the subject here.
Ii was nervous about the whole swap, but love the outcome.
