Aftermarket parts that are better than OEM | Ford Explorer - Ford Ranger Forums - Serious Explorations
I would like to start off this area with two names of aftermarket companies that I think make parts better than OEM.
For suspension = MOOG
Amazing stuff, lasts longer than OEM
And Felpro
Their gaskets are even better than OEM
These are two companies I have never gotten anything bad or defective from.
4pointslow
Explorer Torture Tester
Gloucester City, NJ
98 2Dr,98 & 04 4dr xlt
I would also like to add Simons Autosports for their aluminum thermostat housing for the 4.0 SOHC.
It is amazing, one piece, and did I say aluminum????
Maniak
Moderator-Stock 91-94
Moderator Emeritus
Vail, Arizona
1992 XLT 4x4
I really wished I bought one of these before I lost the first one on our mustang (2006 w/ 4.0 sohc), or maybe right after that.. I've replaced 3 thermostat housings since this part became available and while it's still cheaper to keep replacing (assuming I'm done replacing them) not having to worry about it or have it ruin a day waiting for AAA to take the vehicle home would have been well worth it.
~Mark
Rick
Pumpkin Pilot
Staff member
Admin
Wayoutin, Aridzona
'93 XL '20 ST
Callsign
AB7FH
I am also a big fan of Moog suspension components. They usually provide a product that is at least as good, if not better than stock. Moog often has parts that fix known problems too.
roscoe 0202
salt lake city utah
1999 explorer sport
times two on the fel-pro gaskets
roscoe
ahodges
Millbury, OH
1996 XLT - 347 S/C
In my experience the Ford Racing performance parts are at least as good as OEM, and in the designed application, much better than OEM.
owenbirr
Suring, WI
1994, Explorer Sport
And Felpro
I agree with Moog suspension components, but remember they have to be greesed everytime you change your oil and right after you do any serious offroading. I had a greasable Napa brand balljoint go out within 1 year because I did not keep up with greese. Felpro gaskets are O.K., but nothing to brag about in my book. I had a composite Felpro headgasket fail in only 10,000 mi. It's just paper fiber with some plastic mixed in. The paper disintagrated near one of the cooling ports. I am now using generic cheap graphite head and lower intake gaskets because they seal better and they're metalic quality stands up to heat and pressure. $67 for a complete headgasket kit with bolts off ebay vs $80 for Felpro without bolts from Autozone.
kydirtscooter
ky
2003 Explorer Limited 4x
Loctite Instant gasket works great although a little expensive. As far as Moog, as long as you are paying attention to the part number games they play they are ok. They list the same base number but add to the suffix or prefix and you can get a not domestic part which fails much sooner. Lately we have gone away from Moog for Super Duty parts as even their US parts have been failing earlier and earlier. At least make sure you watch country of origin!
BlueEx00
Fort Worth Texas
2000 xlt 4 door 4x4
What about an aftermarket exhaust?
ElectronFlow
Ever Have The Feeling You're Being Watched??
Georgia
2013 Explorer PIU 3.7L NA
IMO
Moog has a lot a Chinese made parts, you just have to check and see where it's made/
USA or China.
I was assistant manager at a major brick and mortar parts store chain (not Autozone).
Depends on which gasket you are buying from Felpro.
Every manufacturer has cut corners in the name of profit in recent years.
Look at some Motorcraft filters for example, they keep getting shorter.
Sylvania SilverStar Ultra 9005 / HB3
I run this brand in all my Fords and the Mazda.
Samgraybeard
Sydney Australia
2005 3 SE
Keep this thread going, as these vehicles age Ford and other parts manufactures will stop stocking and making parts we have a company in Australia called Rare Spairs it’s important to support these outlets and manufacturers by listing them in threads like this .
