Aftermarket Radio Illumination Wire for Dimming Display
Paul Fithian
Long Beach, IN
2007 Job 1 RWD V8 Limited
To enable an aftermarket radio to dim at night, I hooked up the radio's orange illumination wire through a SPST latching switch, powered from the 12 V outlet feed wire in the console. The switch fits perfectly in the Aux input hole in the console, which you don't need with an upgraded radio.
I have ~ 10 of these switches, PM me and I will send you one for a $2 PayPal.
bdmaash
YYC
'07, '01 sport trac
Why not tie the wire into the HVAC control illumination right below the radio.
I do suppose this gives better control - like auto headlights on most cars that don't turn on tail lights, dimming only when remembered.
Paul Fithian
Long Beach, IN
It’s easy to tap into this circuit and gives you better control of dimming.
V Aftermarket Radio Install 2007 - 2010 Explorer Sport Trac 3
SixPonies "iBoards" Aftermarket Side Steps 2007 - 2010 Explorer Sport Trac 1
S Aftermarket camshafts? 2007 - 2010 Explorer Sport Trac 11
F Really? No aftermarket taillights? 2007 - 2010 Explorer Sport Trac 2
D Aftermarket Sync 2007 - 2010 Explorer Sport Trac 0
T Aftermarket Stereo Sub Click not Pop 2007 - 2010 Explorer Sport Trac 0
I Aftermarket exhaust for 2010 4.0? 2007 - 2010 Explorer Sport Trac 2
adrnlnrush Aftermarket Shocks for Gen2 Tracs 2007 - 2010 Explorer Sport Trac 1
S replace sub and amp with aftermarket need help!! 2007 - 2010 Explorer Sport Trac 2
0 Aftermarket gears? 2007 - 2010 Explorer Sport Trac 3
K Aftermarket Exhaust - blipping the throttle response 2007 - 2010 Explorer Sport Trac 24
D Aftermarket Sunroof? 2007 - 2010 Explorer Sport Trac 12
S help with aftermarket parts 2007 - 2010 Explorer Sport Trac 2
M Dashboard and Radio Lights Don't Work 2007 - 2010 Explorer Sport Trac 2
R 2008 SPORTRAC - BACKUP CAMERA AND RADIO 2007 - 2010 Explorer Sport Trac 4
M Steering wheel radio controller not working 2007 - 2010 Explorer Sport Trac 0
R New Battery, now no radio 2007 - 2010 Explorer Sport Trac 0
G Satelite Radio 2007 - 2010 Explorer Sport Trac 4
A Radio Removal 2007 - 2010 Explorer Sport Trac 2
I Want to add Nav radio w/bluetooth,add sterring wheel cotrols 2007 - 2010 Explorer Sport Trac 3
T Radio options 2007 - 2010 Explorer Sport Trac 1
R Request for those with a '09 or '10 with nav radio 2007 - 2010 Explorer Sport Trac 0
S sync radio system upgrade 2007 - 2010 Explorer Sport Trac 1
S Dash Lights and Radio Randomly Cycling 2007 - 2010 Explorer Sport Trac 2
B SiriusXM radio skips over several channels 2007 - 2010 Explorer Sport Trac 1
T Sirius radio problem? 2007 - 2010 Explorer Sport Trac 3
G Stock XLT '08 phone in radio? 2007 - 2010 Explorer Sport Trac 2
C Sirius radio/antenna/accessory question 2007 - 2010 Explorer Sport Trac 4
S OEM Radio Removal 2007 - 2010 Explorer Sport Trac 25
R OEM Radio Swap 2007 - 2010 Explorer Sport Trac 13
0 Satellite Radio? 2007 - 2010 Explorer Sport Trac 4
N Antenna wire for Sirus Satellite Radio 2007 - 2010 Explorer Sport Trac 3
G 07 Owners with satellite radio 2007 - 2010 Explorer Sport Trac 2
R radio help! 2007 - 2010 Explorer Sport Trac 3
Similar threads
