slaughterrt
- April 11, 2008
- Old Bridge, NJ
- 2011 Explorer XLT
I did a search but I couldn't find the right terms to search for to get a specific result. I did a search and found hundreds of results but none really helped me.
I have an aftermarket Sony head unit in my 99XLT and I am having trouble with one of the speakers. The back driver side speaker is not playing. The speaker itself is not the problem because I switched the speaker into a different slot and it plays fine. So it seems like the problem lies in the wiring. I have checked the solder joints and everything seems ok. I was curious if the amp in the Sony headunit has a fuse in it that maybe blew. I did not see any obvious fuses sticking out of the back of the headunit so I thought maybe internal fuses? I wanted to get some input before I start tinkering with the inside of the head unit.
All the speakers were working at one point, but I messed around with the wires while I was toying with the idea of putting in some tweeters. After I put everything back together (without the tweeters wired in), the back driver side speaker was not getting any sound. Any ideas would be greatly appreciated. Thanks guys.
Also, if it helps, the headunit says "Speaker Failure" sometimes.
