Aftermarket Tail Light Options
klr-b-scl
2015 Ford Explorer Sport
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve
Callsign
VE3
Welcome to the Forum.:wave:
Looks nice but it looks like they show white light in them when activated??
klr-b-scl
Thanks, I went to post and thought I had an account and realized I never signed up. Been stalking for over 3 years and somehow never posted hahaha.
Rainlord
Zurich, Switzerland
Explorer 2012 XLT
Cool lights, I wonder how the build quality is on them for that price, but I do love the look of the break light compared to Ford default.
I see they do another version that extends onto the tailgate, although attachment for that extension with 3M tape seems a little.. "hmm, maybe not". Even if 3M tape can be crazy strong.
Black Eyed
Location
Saudi Arabia
Riyadh
Explorer 2015 base model
They are really nice
i wonder if there is an aftermarket headlights as well
unixadm
2015 PIU Ecoboost
I've had better luck with aftermarket LED taillights than I have aftermarket headlights. I've normally found aftermarket headlights to be of low quality, adjusters which have play in them and overall less than ideal beam options. I've also had them leak.
Rainlord
Zurich, Switzerland
Explorer 2012 XLT
I couldn't resist and just ordered the taillights in smoked black, so I'll post an update once I have them. I'll also post some pics of installation procedure and when they're installed etc. I had to route them shipping-wise via family in the US, so it might take a little longer than usual to get them over here...
unixadm
2015 PIU Ecoboost
I bought a set of the red ones and they'll be delivered today. Unsure if they'll work on my PIU but I'll post my findings during the next few days when I get a chance to install them.
klr-b-scl
Cool I'd love to see images.
My truck is in the shop...string of bad luck with it recently and it's driving me insane. Dead battery, leaking transaxle, cracking seats, door panel falling apart... instead of lights may need a new vehicle. Ugghhhhhhhh
Rainlord
Zurich, Switzerland
Explorer 2012 XLT
Care to clarify on the "fit isn't 100%"? Did you have to modify them in any way?
unixadm
2015 PIU Ecoboost
They are amazing, what about the turn signals ? are they good ?
If you look at the lights, the three small rectangular embedded lights are the brake / turn signal lamps. They are quite bright and include an integrated resistor to prevent hyper flashing. The light tubes are used for the running lights.
I'd say they could hug the body a bit better. You also have to transfer a piece from the stock lamps. When I went to install that piece on the aftermarket lights, the locating dowels were too big to go through the holes so that I could reinstall the 7MM screws. I had to drill the locating dowel holes out slightly to get those pieces to install onto the new lights. Very simple, doesn't affect going back to stock in any way, but it was a minor inconvenience.
will_p
St. Joseph, MO
2013 Explorer Limited
just bought the black/ smoked version of these, they looked too good to pass up... will update on thoughts once i get them
Rainlord
Zurich, Switzerland
Explorer 2012 XLT
Still waiting to install mine as when I tried it, I missed the fact that on older model explorers (11, 12, not sure if others) you need to get a completely different light harness as those lights assume you have twist-in bulbs. It said so in the ebay listing in red, so me not reading that was the biggest mistake in that regard :oops: the harnesses were a little harder to find, but the ID is in the ebay listing as well, so for those that consider these lights with an older model, it may be worth checking your harness first unless you feel like having a harder time installing them :)
will_p
St. Joseph, MO
oh crap i didn't realize it was a harness that was needed... mine is a 13 so hopefully i don't have issues.
(edit) i just looked up the harness look to be about 15-20 each so not bad if needed..
thefranchise713
Buffalo, NY
'18 Toyota Prius Prime
I'm kind of surprised that it's limited to older vehicles, given that the lighting visually changed between 15/16, but technologically it didn't--what was LED was still LED, and what was halogen still halogen.
Rainlord
Zurich, Switzerland
Explorer 2012 XLT
Edit: I'm dumb. I asked where this wire goes, but it connects as a light in the twist-light-socket. So I'll leave this post here in case someone else is having a "dumb day" :D
Rainlord
Zurich, Switzerland
Explorer 2012 XLT
Ok, one question to those that did this. Behind the large black plastic plug of the tail light wiring harness, there's a bunch of wires (5 of them) that go into the body of the car and then connects to a clip. How do you get in there to unclip / clip a new harness on? The hole for the plug is about 2 inches wide, which means no hand can go in there (and the wire is quite taunt so you can't pull on it to get at the clip). I assume one would have to go in from another part of the car, but which? I'd rather not disassemble the whole car to switch out that harness...
Edit: Here's a picture to explain better, the clip is on the right next to the green tape and then the plug.
B 2016 aftermarket tail light options? Modified 2011- 2019 Explorers - Tuning & Mods 3
A Aftermarket Subs with the factory Sony system Modified 2011- 2019 Explorers - Tuning & Mods 1
J Aftermarket Exhaust For N/A Engine Modified 2011- 2019 Explorers - Tuning & Mods 3
X Any Aftermarket brands for our Suspension? Modified 2011- 2019 Explorers - Tuning & Mods 41
D Aftermarket Gauges - Gauge Pods Modified 2011- 2019 Explorers - Tuning & Mods 0
S Aftermarket Cargo Net Modified 2011- 2019 Explorers - Tuning & Mods 3
Zohli Need Aftermarket Horn Help Modified 2011- 2019 Explorers - Tuning & Mods 9
P 2016 base model ford explorer aftermarket dash kit Modified 2011- 2019 Explorers - Tuning & Mods 45
P Using SYNC heated seat switch on aftermarket heaters? Modified 2011- 2019 Explorers - Tuning & Mods 2
C Aftermarket headunit with metra/maestro install Modified 2011- 2019 Explorers - Tuning & Mods 17
D Aftermarket headlights Modified 2011- 2019 Explorers - Tuning & Mods 8
C Aftermarket speaker mounts? On dashboard? Modified 2011- 2019 Explorers - Tuning & Mods 0
I Integrated Aftermarket Stereo - Hopefully soon for MFT! Modified 2011- 2019 Explorers - Tuning & Mods 0
N 2015/2016 Ford HID/LED vs Aftermarket... which is better? Modified 2011- 2019 Explorers - Tuning & Mods 15
P Aftermarket Headlights-where to get? Modified 2011- 2019 Explorers - Tuning & Mods 6
P Aftermarket roof racks Modified 2011- 2019 Explorers - Tuning & Mods 2
I Aftermarket Wheel and Tire Information Thread Modified 2011- 2019 Explorers - Tuning & Mods 1
B Aftermarket mild tone mufflers Modified 2011- 2019 Explorers - Tuning & Mods 0
F Aftermarket Intercooler Modified 2011- 2019 Explorers - Tuning & Mods 3
I disappointed with aftermarket exhaust on sport Modified 2011- 2019 Explorers - Tuning & Mods 7
R Aftermarket DVD head unit - Chinese Modified 2011- 2019 Explorers - Tuning & Mods 11
H Larger Tires on OEM & Aftermarket Wheels Modified 2011- 2019 Explorers - Tuning & Mods 124
M Aftermarket Accessories for Explorer Gen 5 Modified 2011- 2019 Explorers - Tuning & Mods 1
S Aftermarket touch screen with nav for base model .. PIC Modified 2011- 2019 Explorers - Tuning & Mods 20
W 2013 Explorer Sport with Aftermarket Wheels and Tinted Windows Modified 2011- 2019 Explorers - Tuning & Mods 3
S Need Advice for Aftermarket Gear Modified 2011- 2019 Explorers - Tuning & Mods 2
D Aftermarket Sport Exhaust Thread Modified 2011- 2019 Explorers - Tuning & Mods 112
N 3.5L EcoBoost aftermarket programming Modified 2011- 2019 Explorers - Tuning & Mods 27
D Aftermarket Grilles? Modified 2011- 2019 Explorers - Tuning & Mods 10
Z Aftermarket Transmission Cooler Modified 2011- 2019 Explorers - Tuning & Mods 4
2 '12 Ecoboost Aftermarket Parts Modified 2011- 2019 Explorers - Tuning & Mods 2
M Rear Hatch - Aftermarket Trim Modified 2011- 2019 Explorers - Tuning & Mods 6
G Aftermarket speakers Modified 2011- 2019 Explorers - Tuning & Mods 20
E Does it help to swap the standard halogen headlights for aftermarket brands? Modified 2011- 2019 Explorers - Tuning & Mods 11
B Aftermarket Rear seat armrest/console Modified 2011- 2019 Explorers - Tuning & Mods 0
L Aftermarket Crossbars / Roof Racks Modified 2011- 2019 Explorers - Tuning & Mods 40
B Has anyone heard of CGS Motor Sports for Aftermarket Air Intake & Cat Back Systems? Modified 2011- 2019 Explorers - Tuning & Mods 82
H Aftermarket wheels Modified 2011- 2019 Explorers - Tuning & Mods 752
S Installing aftermarket DVD headrests Modified 2011- 2019 Explorers - Tuning & Mods 196
P 2011 Explorer, Aftermarket Rear Seat Video suggestions Modified 2011- 2019 Explorers - Tuning & Mods 17
B 2016/2017 Smoke Tail lights? Modified 2011- 2019 Explorers - Tuning & Mods 11
C Tail light swap? Modified 2011- 2019 Explorers - Tuning & Mods 3
R Tail light cap covers? Modified 2011- 2019 Explorers - Tuning & Mods 4
M Tail light kill switch Modified 2011- 2019 Explorers - Tuning & Mods 12
F Smoke tail/headlights Modified 2011- 2019 Explorers - Tuning & Mods 34
M Tail Lights - Tinting Reversible Mod Modified 2011- 2019 Explorers - Tuning & Mods 13
M Headlight/Fog light upgrade for 2015 Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 21
S led light bar wired to work with only high beams? Modified 2011- 2019 Explorers - Tuning & Mods 7
N Fog Light or High Beam Memory Modified 2011- 2019 Explorers - Tuning & Mods 9
J 17 explorer cargo/trunk light bulb type? Modified 2011- 2019 Explorers - Tuning & Mods 4
Similar threads
