air conditioning only runs for about a minute! | Ford Explorer - Ford Ranger Forums - Serious Explorations
doehunter
Houston Texas
'93 XLT
Hi again,
'93 Explorer, 6 cyl. stock.
Ac blows cold for about a minute then gets hot. I looked and the compressor is not running. Things I did to troubleshoot:
1. I hot wired the compressor it so it would stay running for checking it out.
2. I checked the low side pressure and it's about 45 psi.
3. pulled the hot wire off.
4. check voltage with clutch wires disconnected, 14 volts.
5. check voltage with clutch wires connected, 0 volts.
6. Idle speeds up when I connect the clutch wires.
I'm an AC retard, but I'm hoping this will give you enough information to help me help myself! I really don't know how it all works.
thanks,
Jim
Iron Weasel
Belen, New Mexico
1994 XLT 4x4
R-12 or R-134a?
Is the compressor clutch engaging then disengaging in a cyclic manner every few seconds or is it just not running at all?
doehunter
Houston Texas
'93 XLT
R-12 or R-134a?
No, well not really. I runs constant for a few seconds, then cycles, then stops running altogether. I have heard the cycling on/off indicates low refrigerant pressure. I checked the low side ( only have the one gage on a freon can) and it's good.
Roadrunner777
Bemidji, MN
94 4x4 Sport 88k
I'd get into a chiltons manual or autozone, see what's driving the clutch. I think there are a couple of pressure switches. But, it's not a huge jump to say that the system probably leaked down and needs a can of freon. I'm not an AC person either. When mine goes out, I'll probably just pull it all and convert to heat only.
Iron Weasel
Belen, New Mexico
1994 XLT 4x4
Typically, if the system is above 25psi, then the clutch will engage and run until the pressure in the system hits 25psi then it'll shut off. For example, if you have a static (engine idling with A/C off) pressure of 45psi, the clutch will engage until the pressure drops to 25psi, then the clutch will disengage until the pressure builds back up to 45psi.
Hook your gauge up, start the engine then note the static pressure. Have someone else turn the A/C on while you continue to watch the gauge. If it drops below 25psi, then the clutch should disengage which results in warm air. Normally, the A/C system is closed, so if you're low on refrigerant and you haven't intentionally opened the system then chances are you have a leak.
wood1
North of Edmonton
'93 XLT, Cayman Green RIP
Pretty sure Glacier went into great detail on how to work on the 1st gen air/con system. Do a search. BB is a wiz with that stuff too.
jimpl
houston,texas
93xlt
I was checking the pressure with the ac running. That's why I wired the clutch direct to the battery, so I could do that. The pressure is good. In fact it was a little high and I let some out to get to 45 psi.
My son suggested it might be a pressure switch, but had no ideas on how to test.
jimpl
houston,texas
93xlt
Glacier as in on this site? OK I'll look.
Nomad767
Lake Charles, La
92 Explorer XLT 4x4
I would def go to harbor freight and buy some cheap gauges. Much better to look at an a/c system with both the high and low pressure info. Without that, you are just assuming everything is running perfect when you know there is an issue somewhere. The easiest way to check the pressure sensor would be to jumper the plug for it. That will keep you compressor running constantly with no cycling from low pressure. But without some good gauges, i would not recommend playing around with anything since you don't know what the complete system pressures are.
jimpl
houston,texas
93xlt
OK I'm feeling like a moron now. I've been trying ti use the search thing, and I'm just getting frustrated. I can find a ton of stuff that doesn't apply, but nothing to help me.
A coworker offered to bring in his gage set today and I want to know what the pressures should be on high and low sides when it's running, but I can't find it.
Help?
Iron Weasel
Belen, New Mexico
1994 XLT 4x4
High side pressure should be about 2.2 - 2.5 times the ambient air temperature. Keep in mind that this is a guideline and not an absolute.
So if it's 82 degrees outside, high side pressure should be 180psi - 205psi.
jimpl
houston,texas
93xlt
Thank you so very much.
This is even better than what I was looking for.
I'll go check it out now.
jimpl
houston,texas
93xlt
My pressures were good. I bypassed the low pressure switch, and it worked good.
Hit the parts store, got the switch in, and now I can relax!
thanks guys.
Jim
