SuddenDeath
- June 22, 2008
- Mays Landing, NJ
- 1990 Jeep Grand Wagoneer
Right, now this is a lot of speculation based on what i've learned crawling around inside, under, and through my Explorer during the countless little tweaks I've done to her. I've been reading up on snorkel builds and such, and one of the primary things that has been making me shy away from it is the 'permanentness' of the job. The hole in the fender, frankly, scares me.
So I was thinking one day, about the stock air intake. If I'm correct, the air intake goes from the throttle body to the MAF, then bolts onto the top half of the airbox. From the air box, it goes down another length of plastic 'conduit' and out to the grille of the truck in what is basically an air ram, to get air into the intake.
Here is my idea:
What if, instead of sealing the airbox and removing the air ram and cutting holes in the fender, why don't you use two lengths of rubber hose (because the 'air ram' part I'm talking about ends in two small square inlets), stretch them over the square inlets, clamp them down, and run them up the side of the truck to where a snorkel would normally sit. Go wheeling, when you're done, unclamp and your stock again.
The ultimate goal of this train of thought is to create a snorkel-like device without the invasivness of a true snorkel, but while giving the same protection against water-down-the-intake. What does everyone think of this? Worth a try, or just stupid? ::shrugs::
Here is my idea:
